Here we go...won't start after first snowfall
Old Jan 18, 2016 | 09:48 AM
homeofbacon's Avatar
UPDATED Here we go...won't start after first snowfall
I failed my road test last week which kinda discouraged me so I haven't driven it in at least a week. Temperatures were pretty low with the snow last night so I decided to start her up this morning. Welp, turned over a couple times, then died down. Interior lights and headlights are a little dim but the alarm worked fine so. It's my first time coming across this problem, any suggestions, ideas, fixes? Thank you
UPDATE: Battery connections are good and tight. Very little corrosion, but I poured baking soda/water on the posts to be sure. After turning and holding the key there for a few seconds, there's rapid clicking. I was thinking about picking up a trickle charger but now I'm worried the alternator has gone bad.
Old Jan 18, 2016 | 10:17 AM
DennisMik's Avatar
If the battery is low, that may be the problem. When the temperature drops, the oil thickens and it takes more power to crank over the engine. At the same time, cold temperature reduces the battery's ability to produce power.
Things like alarms don't need very much power. Lights need more, maybe 10 amps, but the starter needs several hundred amps of power. If your lights are dim, that means the battery can't provide quite enough power for them, so forget starting the engine.
Old Jan 18, 2016 | 10:26 AM
So it's just not gonna start until the temperature rises? Lol
Old Jan 18, 2016 | 11:04 AM
Turbobink's Avatar
Old dried out lube in your starter.
Remove, dismantle, re-lube or replace.
Old Jan 18, 2016 | 12:11 PM
If you don't change anything, then yes.
When one lives where there is extreme cold, you gotta have a strong battery (high CCA) and in tip top shape.
Old Jan 18, 2016 | 02:59 PM
Rit's Avatar
Rit
Funny because my Maxima is old enough to take a road test on itself. In a few years it will be old enough to drink.
Old Jan 18, 2016 | 06:02 PM
Half Assed's Avatar
Take the battery out and have it load tested at the auto parts store.
I have a 48-series battery in mine that I got out of a chevy truck from work. IIRC it puts out about 770cca. You could probably crank the starter until it burned up before the battery goes dead lol.
Old Jan 18, 2016 | 06:38 PM
JvG's Avatar
JvG
Are you sure that your battery terminals and cable ends are free from corrosion and shiny? If not, clean them with steel wool or fine sandpaper.
Electrical contacts need to be clean to start the engine on a cold day.
Agreed on having your battery load tested.
Old Jan 18, 2016 | 10:24 PM
McJonny's Avatar
How bout you try just jumping the battery first, lol.
+1 for load test
Old Jan 19, 2016 | 07:37 AM
njmaxseltd's Avatar
Replace the battery.
Old Jan 20, 2016 | 07:00 PM
Finkle's Avatar
New battery, or at least charge the one you have. Clicking is a classic sign of not enough juice. I put one from a Bonneville in my Max. Starts so fast you don't really hear it crank. Its amazing the difference a new battery makes. IIRC the bonneville battery is a couple hundred more CCA than the stock max battery. I had to cut off the terminals and put side screw on type mounts, but it was worth it. +
My wife totaled out her bonnie with a two month old battery in it. I pulled it out before it want to the junkyard.
denormalize
Nov 13, 2019 12:51 PM
CS_AR
Nov 25, 2015 06:01 AM
Mrbizness1
Nov 14, 2015 05:15 PM
kmitchel
Nov 13, 2015 06:37 AM
TxBroncosFan
Nov 12, 2015 12:07 PM
