1997 Maxima Hesitating.
Old Feb 22, 2016 | 06:14 PM
bassmann's Avatar
Hi, the car is hesitating to accelerate from a stop. It doesn't happen all the time. Has any one had this problem? Please help if you can.
Old Feb 22, 2016 | 06:58 PM
ShunDoe's Avatar
Have you tried check the Mass Air flow sensor? Maybe check the transmission level!
Old Feb 22, 2016 | 07:06 PM
bassmann's Avatar
I cleaned the Mass Sensor about a year ago. The Transmission fluid is level. The service engine light isn't on either.
Old Feb 22, 2016 | 07:11 PM
ShunDoe's Avatar
I'd say try spaying some B-12 inside the throttle body to clean the composites
Old Feb 22, 2016 | 07:12 PM
bassmann's Avatar
Do I have to take it off?
Old Feb 22, 2016 | 07:16 PM
ShunDoe's Avatar
You can just open up the housing where the air filter goes and as you give it a little gas spray a little B12 . Too much B12 will stall the engine, but you should be able to start it back up if that happens
Old Feb 22, 2016 | 07:17 PM
bassmann's Avatar
Thanks for your help.
Old Feb 22, 2016 | 07:34 PM
ShunDoe's Avatar
No problem, hope it helps. If it does helps then then add a can of B12 to your gas tank after every oil change. That should keep everything clean.
Old Feb 22, 2016 | 10:42 PM
bumpypickle's Avatar
Take off your intake starting from your airbox all the way to the throttle body and clean everything with brushes and intake cleaner. This is very easy. Takes me about 30 mins to take off, clean thoroughly and reattatch everything. Next you'll want to change out the spark plugs which is easy but a little more involved.
Old Feb 22, 2016 | 11:30 PM
some links for you:
Full intake/egr cleaning
https://maxima.org/forums/4th-genera...g-dummies.html
note: If you do not have an egr code, I would not worry about the egr tube at this time, maybe clean the sensor going into the tube.
Spark plug replacement:
Note: Anything ngk are good for plugs. I (and lots of others) use ngk coppers becuase they are cheap and perform well.
Old Feb 24, 2016 | 12:07 PM
JvG's Avatar
JvG
Be careful regarding what you spray in the throttle body. I've never heard of spraying b 12 in there.
The throttle body has a Teflon coating inside it. Harsh chemicals can harm that.
CRC corp makes two good chemicals which are intended for this purpose. One is called Throttle Body Cleaner.
The other one is called Mass Airflow Sensor Cleaner.
Both are sprays.
The maf cleaner might help solve this.
Old Feb 25, 2016 | 05:45 AM
M in KC's Avatar
For sure clean the intake system as has been suggested. But even after all that my symptoms were similar to yours with no CEL lit. Driveability was terrible to the point of almost unsafe. My issues ended up being the intake air temperature sensor and the MAF itself.
lowriderman3
Oct 4, 2016 11:55 AM
max ride 41
Feb 21, 2016 08:13 PM
Octo
Feb 21, 2016 03:00 PM
bbsitum
Feb 20, 2016 12:05 PM
Will
Feb 16, 2016 04:17 PM
