need help diagnosing starter issue
Old Feb 23, 2016 | 01:06 PM
surban1's Avatar
sometimes the starter does nor engage and all I get is a click
it happens rarely and usually will then engage and start right up on the next try or two but this morning I had to try ~ a dozen times before it engaged, so i'm getting concerned (don't want the wife to have any issues when she uses it occasionally). since I hear the click and all dash-lights go off, i'm thinking that it's not the solenoid and the battery is tip-top for sure; I also have additional grounds all around (and to starter) so i'm wondering if this indicates starter needs a re-grease or is the starter on its way out. car has ~ 190k and this is the second starter (a reman was put on by dealership at ~ 135k in 2007). I've recently put shims into the ignition switch but that didn't seem to fix this issue. thanks in advance for any assistance.
Old Feb 23, 2016 | 05:37 PM
JoshG's Avatar
I had put in a new starter back in November, and when it failed all I got was a click and the dash board lights would go off when I attempted to turn it on, after installing a new starter..fired right up.
Old Feb 23, 2016 | 05:54 PM
ShunDoe's Avatar
Y'all max sound better then mine. I don't even get a click. It makes no noise when my starter is out. I've been through 2 starters in the past2-3 years
Old Feb 24, 2016 | 06:15 AM
M in KC's Avatar
If your battery, grounds and ig switch are all known good then your starter is on its way out. Pretty typical symptoms at least from my experience. Hopefully you got a lifetime warranty on your starter and you are just out the time to swap it out.
Old Feb 26, 2016 | 07:02 PM
bbsitum's Avatar
Do you guys try to search this forum as I did and anyone else.
Old Mar 29, 2016 | 12:20 PM
hithesh's Avatar
I am having similar issues.
What's a good starter?
Autozone or Nissan oem?
How much is the Nissan reman.
Old Mar 29, 2016 | 07:34 PM
JvG's Avatar
JvG
Members have reported having issues with Auto zone starters several times.
Old Mar 30, 2016 | 07:04 AM
M in KC's Avatar
Nissan will not sell a reman starter, new or nothing from them. It's a crap shoot with any parts house starter. If you go the reman route get one with a lifetime warranty so the next time you are only out your time. I've had to do this with my Advanced Auto Parts starter FWIW.
Old Mar 30, 2016 | 11:03 AM
quxs's Avatar
Had the same problem. If it's still clicking you should be able to get it to start by trying enough times. Eventually mine stopped clicking at all and had to replace it with this from
Amazon Amazon
. Easy enough to do myself. Works great, haven't had a problem yet after 3 months.
Old Apr 2, 2016 | 04:56 PM
asand1's Avatar
Could be the brushes, or the contacts within the starter, geasing would not help this condition. I would just replace the starter after checking voltage and connections.
spamaster
Mar 23, 2016 03:38 AM
trentonlambert
Jan 31, 2016 11:38 PM
DjSinikal
Jan 29, 2016 12:39 PM
DeusExMaxima
Jan 29, 2016 12:36 AM
Maxima 97 SE
Jan 27, 2016 09:38 AM
