Please help new max
Old Jun 15, 2016 | 07:26 PM
maxedover's Avatar
Please help new max
98 gle
2 days after buyin the max i bought a new starter and put it in....didnt start....so i jumped it and it started...drove it for half a day and now it wont start again even with a jump...the bat is good...and im wonderin if i got a bad rebuilt starter...my question is...If the bat is 12.3 volts and seems good...would a bad altinator stop it from starting even with a jump..i dont know what to do next buy another starter ...
thanks!
Old Jun 15, 2016 | 08:14 PM
maxedover's Avatar
Originally Posted by maxedover
98 gle
thanks!
forgot to tell ya, when it started with a jump the meter said 14 volts when it was running but i didnt have lights on or any load really...could it be the alt. makin it not start even with a jump?...or maybe ignition swith...it just clicks fast when i try to start it
Old Jun 16, 2016 | 08:07 AM
maxedover's Avatar
Anyone?...
it seemed 3 yrs ago when i was a member there were alot more readers of the 4th gen forums....
i wish i remembered my original name and password...
Old Jun 16, 2016 | 10:34 AM
JvG's Avatar
JvG
After you jump the car, disconnect the jumper cables . Measure the voltage while the car is running . Should be close to 14 v even with some accessories on.
If you get 12 v or so, the charging system has issues.
Measuring battery voltage while jumper cables are still attached probaby measures the voltage of the other cars alternator.
Old Jun 16, 2016 | 12:36 PM
DBear's Avatar
Normally if your alternator is bad, you can start the car with a jump but it will die immediately (assuming the battery has already completely run down). If it won't even turn over with a jump, it sounds like a bad starter. There are lots of threads on here from people who put in "new" starters that turned out to be bad (most of them are rebuilts). I've never heard of a bad alternator keeping it from starting at all with a jump.
Old Jun 16, 2016 | 01:17 PM
maxedover's Avatar
thanks..i guess i will have to buy another starter and try it again.....has anyone ever had a bad ign switch that just makes the starter click fast?
SquidBeak
Apr 27, 2016 04:21 PM
97_GXE
Apr 24, 2016 02:03 PM
bumpypickle
Apr 23, 2016 04:13 PM
Pnjboyzz
Apr 16, 2016 10:06 PM
nawras
Apr 11, 2016 06:23 PM
