1999 nissan maxima cranks won't start up
Old Jul 30, 2016 | 06:41 AM
Livefree's Avatar
I've changed the starter , crankshaft sensors,cam sensor, knock sensor ,and fuel pump is good ,
Old Jul 30, 2016 | 01:57 PM
JvG's Avatar
JvG
is a red light on? did the alarm go off?
Old Jul 30, 2016 | 02:01 PM
Livefree's Avatar
no red light alarm didn't go off
Old Jul 31, 2016 | 10:41 AM
DennisMik's Avatar
I'm pretty sure JvG is referring to the security light on the dash to the left of the steering column. Is this the light you are telling us is not on?
Old Jul 31, 2016 | 11:10 AM
Maximus909's Avatar
Check for Spark yet?
Old Jul 31, 2016 | 05:50 PM
Livefree's Avatar
yes that light is not on unless i turn the key to on , and yes i have spark ,can a bad fuel damper stop the flow of fuel
Old Jul 31, 2016 | 07:34 PM
DennisMik's Avatar
The red security light being on when you are trying to start the car is you problem. The car is immobilized by the NATS system and the ECU has turned the fuel injectors off.
Old Aug 1, 2016 | 11:32 AM
Livefree's Avatar
all the lights on the dash bord are on when iam bout to crack it and how would i check or turn that off if the case
Old Aug 1, 2016 | 05:51 PM
JvG's Avatar
JvG
Please look at the blue bar near the top of this screen. you will see a Search button. enter something like:
1999 nats no start or similar terms.
there should be several threads about this issue.
Your situation is a common problem with those.
Did you reach through the open window on the drivers door to start the car instead of opening the door, then start the car?
Our cars don't like that, especially the 1999 model.
ctwoody
Aug 9, 2016 01:28 PM
Classicbuff
Jun 15, 2016 03:01 PM
maximachandler07
May 27, 2016 07:34 PM
Boston003
May 17, 2016 07:03 AM
homeofbacon
May 13, 2016 10:05 AM
