95 wont start
Old Aug 2, 2016 | 09:34 AM
michellegoodou47@gmail.co's Avatar
95 wont start
My car wont start. Ive changed the sparks, the cam and crank sensor. The fuel pump is turning on. I need help asap. Ive been needing to get the valve cover changed, could that be the reason? I cant get it to auto zone to get the code reader hooked up to it, because it wont start. Any help???
Old Aug 2, 2016 | 10:09 AM
Need more info.
Does it crank at least?
BTW, your leaking valve cover has nothing to do with the starting problem.
Have you searched? This topic has been covered a million times, and more than likely, the solution to your no start issue has been answered. Start by checking out the other 'no start' threads within the first few pages.
Old Aug 2, 2016 | 10:19 AM
Its cranking, just wont start. Ive read other posts, thats what made me think to change the sensors and spark plugs. But none of that is working. Ill go look one more time. Ive been seeing the egr valve. But does that cause a car not to start.
Need more info.
Old Aug 2, 2016 | 10:34 AM
martyl45's Avatar
try the ECU self diagnostic screw for finding the codes(if yours is still on there). Directions are under the "How to" forum.
Old Aug 2, 2016 | 01:16 PM
JvG's Avatar
JvG
Without a code reader you are flying blind.
Please buy an obd 2 compatable code reader.
Then you will be able to read the codes. The car does not need to start or run when the codes are read.
We might be able to help you once we have a code to work with.
Sam Maxima
24
Sep 10, 2025 06:14 PM
Knotz428
Mar 13, 2016 07:44 AM
slickblack94
Feb 29, 2016 10:33 AM
ZerotoSixty
29
Feb 29, 2016 05:13 AM
