95 96 rpm problems
Old Aug 21, 2016 | 11:26 PM
loudmaxi's Avatar
95 96 rpm problems
Second tach to go bad. I no its very common. Has anyone found a permanent or good solution to this. If not Should i just hook up aftermarket tach instead of dealing with replacing it all the time.
Old Aug 22, 2016 | 08:26 AM
lux97Max's Avatar
97 cluster is the solution
Old Aug 22, 2016 | 10:37 AM
loudmaxi's Avatar
ok but its 97 and up digital odo. how would I make that work. theres no way it just plugs right up and works
Old Aug 22, 2016 | 11:07 AM
JvG's Avatar
JvG
Your assumption about them breaking all the time is incorrect.
I have driven mine for 10 years and have not had a problem.
the teach and Speedo do have a problem which can easily be solved with a soldering iron.
they are screwed into the instrument panel. the screws act as grounds or carry current. the solder connections on each side of the screws can crack front vibration over time. melting the solder and maybe adding a tiny bit of solder often fixes the problem.
Old Aug 22, 2016 | 12:25 PM
loudmaxi's Avatar
Tried resodering both of them. Nothing changed sadly. What is your suggestion with getting another one. And 95 96 97?
Old Aug 22, 2016 | 06:04 PM
lux97Max's Avatar
Recently my cluster was giving me problems , i tightned all the screws cleaned contacts nothing seemed to work. Until i swapped out the cluster plate on the 96 and it worked. Nissan still sells them. Looks like this, 97 is the same as 96 just with new look.
Old Aug 22, 2016 | 07:54 PM
loudmaxi's Avatar
Wow that looks crazy different but it hooks right up Gauge screws and all?
Old Aug 22, 2016 | 08:07 PM
lux97Max's Avatar
This cluster plate is from 98-99 it is different.You need one from a 96 similar to the pic i posted. Im not saying this will fix your problem. This worked for me. Even after fixing the problem i still swapped in the 97 odometer.
Old Aug 22, 2016 | 08:37 PM
loudmaxi's Avatar
Thanks bro.
Old Aug 22, 2016 | 11:14 PM
JvG's Avatar
JvG
I have a 96. My Speedo was not repairable by me. so bought a cluster from a 97 .
Direct plug in.
came from Craig's list.
Old Aug 23, 2016 | 03:27 AM
flynlr's Avatar
Attachment 9497
nissan part number?
Chdmorrison
Jul 12, 2016 11:28 AM
pahanorlando
Jun 29, 2016 07:56 PM
kacielyne
Jun 17, 2016 08:10 AM
reallywildstuff
Jun 9, 2016 03:11 PM
Ray229Harris
May 27, 2016 10:11 AM
