Replacing my Wheel bearing and I guess axle now. Help!
Old Jul 9, 2016 | 09:26 AM
Chdmorrison's Avatar
Exclamation Replacing my Wheel bearing and I guess axle now. Help!
I ran into an issue when replacing my wheel bearing, and no I have to replace my Dr side Axle too. Any input on how to do this? Does it just pop out? Does a ton of fluid leak out?
I have purchased a new axle, a new axle nut, the axle seal for the CVT and 2 quarts of CVT fluid.
Also when i searched the forums I found that you could remove the axle without removing the spindle. Is this true? they said just loosen the the struts bolts. What your input on the is?
Attached Thumbnails Replacing my Wheel bearing and I guess axle now. Help!-13615512_1165864000103234_7552153965843817297_n.jpg   Replacing my Wheel bearing and I guess axle now. Help!-13606687_1165864026769898_579863505278371561_n.jpg
Old Jul 9, 2016 | 10:19 AM
14blackbeauty's Avatar
yes it is true search you tube, it is very helpful, it is an easy job to do if you have the right tools I see you have tried to take off the axle nut already, it is tight so get good tools
Old Jul 9, 2016 | 10:52 AM
Yes we tried. The threads were screwed up on the axle. Like someonw had dropped a rotor on them. We heated it and it seized up both direction with a 4 foot breaker. We then tried a bunch of different things. Long story short the nut isnt coming off unless we cut it and i expect damage to the axle so i figured id replace it anyways. I cant find anything for our Gen. And i dont know if the older gens are the same.
Old Jul 11, 2016 | 06:52 AM
Icecold's Avatar
A few years ago I replace my axle and it was straight forward per youtube. I socked the main bolt down with PB Blast and the bolt came off slow and hard. Youtube was right on target and just the reverse when putting it back together was very easy, just took sometime. I remember marking lines on the strut assembly and was very close when getting my front-end alignment.
Old Jul 11, 2016 | 07:48 AM
Thanks guys got it done. Now i am going to have the cvt fluid changed because the only thing i had access to was vavloline cvt fluid.
Old Jul 11, 2016 | 07:51 AM
Icecold's Avatar
Awesome! You've saved yourself a ton of cash by DIY....
Old Jul 11, 2016 | 01:54 PM
andremike's Avatar
are the wheel bearings a common problem? I noticed a strange vibration when turning left. never noticed it before.
Old Jul 12, 2016 | 11:28 AM
LSExplorer22's Avatar
Wheel bearings were a common repair for me. I've had to replace a wheel bearing on all 4 sides for a total of 5 times. I do all good smooth highway driving so I don't know what the deal is. My last bearing was at 104,000 miles on a 10 Max.
ColdCananda
Apr 15, 2016 01:13 AM
beatdown97
Feb 24, 2016 09:29 PM
ColdCananda
Feb 16, 2016 03:50 PM
cardana24
Feb 12, 2016 09:45 AM
punkdork
Sep 11, 2000 01:38 AM
