water pump suggestion
Old Sep 9, 2016 | 08:16 AM
slfalco's Avatar
Finally tackled this job, what appears simple is a real pain due to limited access.. One thing I did that may help others... When reinstalling the covers for the water pump and tensioner, I inserted M6 studs (about 3/4 inch long) into 2 of the 4 holes, to act as guide pins to locate the covers.. Once the cover is pressed into place, add the 2 retaining bolts to the empty holes, then remove the studs and add the other 2 bolts... Given the lack of space to work with, I really had no idea how I was going to hold the cover in place to start the bolts without making a real mess.. hope this tip helps someone out...
Old Sep 9, 2016 | 12:25 PM
DBear's Avatar
I did the same thing, and it definitely helped, but I was still worried that I smeared the RTV getting it in place. If I was doing it again, I'd stick a magnet on the outside of the cover so there would be something other than the edges of the cover to hold onto.
Old Sep 9, 2016 | 01:14 PM
lux97Max's Avatar
Use orange rtv to seal.
jfredlocks
Sep 6, 2016 08:47 PM
AzureblueZ
Aug 28, 2016 06:19 PM
To the max!
23
Aug 23, 2016 04:46 PM
AEKnight
Aug 13, 2016 05:49 PM
L_U_D_I_AMaxima
Aug 11, 2016 06:43 AM
