Gen 4 Fog Light Install - Help
Old Sep 17, 2016 | 12:40 PM
thankumuch's Avatar
I have a 97 GXE that came WITHOUT fog lights, but I would like to add some factory (salvage) fog lights. I was happy to notice the wiring harness for fog lights is already there from the factory; they just bundled up the unused electric leads with electrical tape and tucked them in there. If I install the factory brackets and lights, then plug in these leads, will I get lights, or do I still need to add a switch to give them power or on/off capability? These current leads branch off the wiring going to the turn signals. I believe the cars that came with fog lights had an added switch included on the regular light control stalk. I don't need to re-do that stalk... actually I'd be happy to have the fog lights on anytime the headlights were on. Anybody that can help me, much appreciated.
Old Sep 19, 2016 | 12:03 PM
Same question came up about a month ago, and many times before.
Curious, do you know how to use the Advanced Search function here on the Org? It's a great tool to use.
Here's the recent thread. Answer is in post #2.
https://maxima.org/forums/4th-genera...-prewired.html
Old Sep 20, 2016 | 01:34 PM
thankumuch's Avatar
When nobody responded I started searching and found some answers, but in all that, no one made real clear how to tap into the marker light wiring, i.e. if I power fogs off that wiring, instead of the signal stalk. What color wire gets spliced into what color wire, etc. Apologies if this is a common question, but I'm not finding an answer.
Old Sep 20, 2016 | 06:33 PM
DrewFree's Avatar
From my understanding since you are pre wired you just need to get a stalk from a 99 that had fog lights factory.
If you dont feel like getting the stalk your best bet is to go to the link wizard referred to.
Note: my car was not prewired at all and i used the info in the thread wizard posted and i have foglights wired independently to a switch i can turn on and off whenever and it was fairly simple using the wiring diagram
Old Sep 20, 2016 | 08:48 PM
You have your answer now, correct? Get the parts I listed in the linked post #2 and you're good to go.
Old Sep 21, 2016 | 06:48 AM
thankumuch's Avatar
Thanks all.
DuaLMaGz
Mar 22, 2019 01:19 PM
A99MAXIMA
Aug 8, 2016 01:58 PM
chevyman1980
Jul 6, 2016 06:54 PM
specfiji
Jul 3, 2016 03:42 PM
maxima2fst4u
Jul 2, 2016 07:20 PM
