95 maxima will not start after it gets warm
Old May 25, 2017 | 03:15 PM
Trellyboy's Avatar
I have a 95 maxima wit the 3.0 I changed all sensors and she will start up and run but once I stop somewhere and cut it up it will not start
Old May 25, 2017 | 03:54 PM
Rit's Avatar
Rit
need help - what do you mean by "cut it up" ?
Old May 25, 2017 | 03:58 PM
Trellyboy's Avatar
My fault when I cut it off I can ride all day but soon I stop and turn the car off it will not start up till about 45 to 50 mins and then it won't start on the first turn
Old Jan 24, 2019 | 09:00 AM
emilianonp's Avatar
I have the same problem..
Did you find a solution? let me know please
Thank you
Old Jan 24, 2019 | 10:29 AM
JvG's Avatar
JvG
The original poster used strange terms.
Please describe YOUR problem , in your own words.
Old Jan 24, 2019 | 05:22 PM
Jack Sh!t's Avatar
Possibly leaking fuel injectors or a bad fuel pressure regulator. My Maxima wouldn't turn over with one leaking fuel injector when it was hot unless I kept cranking it while giving it a little gas.
Old Jan 25, 2019 | 03:33 AM
CS_AR's Avatar
I've experienced a condition like with two leaking injectors. Basically the leaking injectors o-rings let fuel from the pressurized fuel system drain into cylinders when the engine has been shut off. Too much fuel leads to a flooding condition. The only I could get mine to start in this situation was to hold the accelerator to the floor (at WOT) to let the most air enter the intake to clear the flood.
This may have been mentioned before, but an Engine Coolant Temp Sensor (ECTS) could be failing and giving the ECU an incorrect temperature for a warm engine. It may be defaulting to a cold engine reading that would setting up a "rich mix" condition that is incorrect for starting a warm engine. A failing ECTS has been known to contribute to some hard to start conditions.
Old Jan 27, 2019 | 02:45 AM
max ride 41's Avatar
shouldn't it throw a code for that sensor though? i've been having problems with my max stalling after warming up and someone suggested this sensor before.
Old Jan 27, 2019 | 03:28 PM
JvG's Avatar
JvG
Sometimes sensors fail without setting codes.
That sensor could be removed, then tested with a vom, a meat thermometer, and a pan of water which is gradually heating on the stove.
Look this method up on you tube.
Old Jan 27, 2019 | 06:05 PM
Jack Sh!t's Avatar
You will only get a code from this sensor if there is bad connection to the sensor or no connection. The ECU doesn't know if it is reading a wrong temp for this particular sensor.
Old Jan 27, 2019 | 08:39 PM
My money is on a bad ECTS or FPR. I've seen both prohibit a car from starting after it's been driven a bit.
Old Jan 28, 2019 | 08:31 AM
fpr is new, will a bad ects cause gas smell? i mean, i guess that would make sense being as that it makes the engine think its cold when it's warmed up.
Old Jan 28, 2019 | 12:25 PM
JvG's Avatar
JvG
No, it controls air flow.
A defective one leads to stalling. Due to insuffienct air flow. The computer will reduce the amount of fuel injected.
Old Jan 28, 2019 | 03:04 PM
DennisMik's Avatar
Gotta disagree with you. The ECTS reports temperature to the ECU. The ECU adjusts the timing of the fuel injectors accordingly to increase or decrease the amount of fuel. Nothing controls air flow except the throttle plate and the IACV.
The MAF could be a player in this.
To the op - the next time the car won't start, unplug the MAF and see if the car will start.
Old Jan 28, 2019 | 05:03 PM
JvG's Avatar
JvG
Fair enough. I had confused this with the iacv.
slickblack94
May 20, 2013 11:42 PM
mikey62681
63
Dec 20, 2012 10:08 AM
mechanicaljoint
Mar 16, 2005 05:45 PM
unconvinced
Mar 2, 2003 09:36 PM
