Short Throw shifter mod for 4th and 5th gen
This very simple mod consists of simply moving the nylon pivot ball up the shifter shaft to achieve more desirable shifter geometry.
This is the way Nissan should have made the 3.0 shift from the factory. It's free to do, and it shifts way better then those junk eBay short-throws. I've done this on my 4th gen, and now on my fiance's 5th gen. So I figured I'd make a little how-to video this time around.
Nice job Bryan! Not too drastic. I know a guy who cut off and re-threaded stock shifter rod. Though I didn't get to drive to car to see how it would shift.
Do you have any idea where we could get some of the white plastic linkage bushings with inserts? I've got one 5-MT where the rubber insert is all but gone. I've been thinking about buying a stick delrin plastic rod where the rod's OD would be the ID of the shifter mechanism where the bushing is located. Then I would bore out a hole just large enough for the bolt to run through it.
Thanks. I'd say cutting the shift lever shorter should shift great, but there wouldn't be much reduction in shifter throw because the fulcrum point remains in the same position relative to the shift linkage. This method actually extends the throw below the fulcrum in addition to lowering the shifter, the same way a good aftermarket short-throw is configured.
As for finding bushings, I've been seeing a lot of part-outs on my local Maxima Facebook groups.
Thanks. I agree about the short-throw configuration.
I might find some replacement bushings that could be modded to work through the z32 community. Here's a picture of a z32 setup with a bronze bushing.
It does looks very similar to ours. When I scroll up to the picture in my first post, it looks like the inner diameters might be different though. I think I might actually have a set of the bronze Z bushings at my shop. One of my friends tried them on his z32 and he ended up not liking them. So he went back to the stock bushing.
I'm interested to see how that would be done. It seems like it would be impossible on the linkage operated 5 speeds. Maybe it was on a cable operated 6 speed. That seems more doable.
https://maxima.org/forums/5th-genera...arts-list.html
Today a set of z32 shifter bushings from Z1 Motorsports from my Monday order. I like their fast delivery.
https://www.z1motorsports.com/transm...gs-p-1874.html
I think I could make the bronze bushings work in a pinch. The bushing installed in the picture is just a little small. It does not fit tight inside the hole. I could use something like JB Weld to fill in the gap. The inner diameter for the bolt is perfect though. For the shifter end bushings, I would need to drill out the inner diameter then polish down the outer diameter to fit inside the inner diameter. Again, with some minor adjustments, I could make the bronze bushings work if I was in a pinch and had no alternative.
