1157 Wattage
Re: 1157 Wattage
Originally posted by KrZyMaX
Options Auto Salon sells the Polarg 1557 hyperwhites one for 35/5W and the other 21/5W. our suggested is 27/8W. which one do i buy?
The 35/5s are only 8 watts (30%) higher than recomended so they are probably safe.
I could easily be wrong here, but I seem to recall someone saying the the 97-99 Maximas don't even use the higher wattage filament unless you rewire them. If this is indeed the case, there will be absolutely no difference between the two on your car (unless you have rewired).
Either way, I would just go with the 21/5s just to be on the safe side.
Originally posted by sil SE
mine say 12/28 i think theyre hiper industries-
shoudl i be ok?
shoudl i be ok?
actually im going to answer my own question. the low filament is 12 and the high is 28 and i shaved the nub cuz its really a 1156 bulb. so im running the high 28 and the recommended high is 27. (which is not usually on all the time in a stock setup) but i guess il be alright. if you dont think so , let me know.
Originally posted by Ravq
1156 bulbs are single filament. How can it be 12/28w? Are you sure it isn't an 1157 (dual filament)?
1156 has the two nubs that are on the same level right? cuz thats what they were. 1157 has two nonleveled nubs.
so it was a 1156, and the rating says 12/28..got me.
either way im sure its a 28 output that im runningnow cuz its bright. in either case you think im gonna be alrite?
hmm i think youre right.
SuDZ
Originally posted by SuDZ
Upgrade your fuse from like I think it is around 7 or so. Stick a 10 in there.
SuDZ
SuDZ
if i get the higher wattage bulb, would upgrading the fuse to a 10 do the job? what about the harness and stuff? where do i get that and how do i upgrade those?
which name is it under?
ny96max
Dec 17, 2000 04:13 AM
