3.5 Swap Takeoff Squeal and/or shake
Old May 11, 2018 | 04:13 PM
Violator's Avatar
The shake was just me adjusting to the stronger clutch
3.5 swapped car manual transmission, When taking off from a dead stop to 1st or sometimes when I shift into second and less commonly third I get a EEK squeal noise right at the very end of the clutch travel, even when i try slow takeoffs. Length of squeal correlates with the speed of release. Cold or warm wet or dry. Noise isn't 100% of the time but 90% and it doesn't seem like I have any influence over when it does it even on the slowest possible takeoff it will do it.
This car sat for 2 years before i bought it, and the clutch line wasn't able to work even momentarily after trying to bleed it so i replaced it with a stainless steel 1 piece line. I did read that leaking clutch fluid onto the ?flywheel? can cause an issue like this. I have no experience with a clutch/transmission internals but I may be learning soon.
I have tightened power steering belt and the drive belt with no change. Just today I realized while the car was idling (trying to pinpoint a rear header leak) that the power steering pulley wobbles pretty harshly, idk if this is from tightening it or the pulley/pump going bad. Looking into replacing the pump so i don't have to deal with leaks or replacing it down the road
Old May 11, 2018 | 04:24 PM
JvG's Avatar
JvG
Does the noise happen when you accelerate gently, like in city traffic, or mostly when you are out having fun with the gas pedal?
Old May 12, 2018 | 10:21 AM
Violator's Avatar
Light accelerations I just stopped and rolled 15 times on the street and I couldn't help but get a squeal half of the time. I'm trying to come off the clutch nice and smooth and I still get a squeal and or shudder 50% of the time like I wasn't smooth enough with the clutch but this isn't my first rodeo I've got a good touch when it comes to the clutch
Old May 12, 2018 | 10:54 AM
JvG's Avatar
JvG
What' your idle speed?
Do you shift at somewhat high rpm then engage the clutch a bit harshly?
Will the increase in HP take a litthe getting used to?
I take it on faith that you installed your clutch correctly.
Old May 12, 2018 | 12:07 PM
Violator's Avatar
I didn't install the clutch myself, I bought the swap after it hadn't ran in 2years he said there was an MAF issue and needed an ecu but there was some pretty good vacuum leakage
The idle speed is 700 or 1200, the brown idle speed connector is partially broken on the part that actually locks it fully in place so if I drive it down the road it becomes partially disconnected, as soon as I push the connector down with my thumb you can't even tell it moved but the idle goes right to 700 and will stay there until you drive it down the road and it will be back at 1200 until I put a little pressure on the connector again.
EDIT: this TPS issue was actually due to the metal TPS piece that spins having too much contact with the peice against it to the throttle body causing it to stick and the pressure on the connector was just enough to push the tps away and unstick it
Old May 12, 2018 | 12:17 PM
JvG's Avatar
JvG
I bought a similar connector for a friend last week.
11 dollars on Amazon. Sure, the jy would be about free.
your idle speed, even at 1200 would not cause the issue you have.
Old May 12, 2018 | 12:28 PM
Violator's Avatar
It sounds almost like a belt slip or tire squeel it's usually a fairly quick noise maybe half a second but sometimes it can stretch out to maybe aa secon and a half
Old May 12, 2018 | 01:21 PM
JvG's Avatar
JvG
I'd believe a belt squeal. How tight is your serp belt?
Deflection with moderate finger pressure should be about half an inch.
Does the sound occur more after rain, or when it is dry outside?
Is it sound worse with the A/C on, or off?
Old May 14, 2018 | 09:28 PM
fattmaxx02's Avatar
Check your subframe x member torque specs,had a similar sound on my 02 after clutch job,should be around 90 to 120ft lbs ish if I recall.
Old May 14, 2018 | 09:33 PM
fattmaxx02's Avatar
Also if u used poly trans and or pass side poly mounts,and if used a grease or lube to I y'all mounts in shell ,they will squeak on torque engagement,ie take off,ask me how I know...good luck.
Old May 14, 2018 | 09:36 PM
fattmaxx02's Avatar
Almost forgot one last thing,does it do it more when cold,like 1st start up and shortly after,does it go away through out use during the day,if so could be rear main leak on flywheel.
Old May 14, 2018 | 10:27 PM
Violator's Avatar
I got the guys number so I'll send him a text and see if he remembers anything about the mounts. I did tighten the belt with no change. might be getting some t-storms tomorrow to see if wet conditions affect it i can't recall off the top of my head
Old Jun 21, 2018 | 12:21 PM
Violator's Avatar
Still suffering from squeal, have noticed a very wobbly power steering pulley looking into replacing the pump if that's my best option
Old Jun 21, 2018 | 01:36 PM
JvG's Avatar
JvG
Gosh, Violator, you probably found the source of your squeel. It would be a loose power steering belt.
Old Jun 21, 2018 | 07:32 PM
oldngivout's Avatar
Willing to learn
It could be the crank pulley outer ring walking in toward the engine slightly on acceleration.
Rubs the PS belt when it does. Had that happen to me.
Old Jun 21, 2018 | 07:33 PM
Violator's Avatar
That makes the power steering pulley wobble?
How did you fix that? It's a UDP crank pulley
Old Jun 22, 2018 | 12:06 PM
CS_AR's Avatar
It happens with regular stock pulleys. I've replaced 4 so far.. I need to do the 99 model in the fall..
Old Jun 22, 2018 | 02:21 PM
Violator's Avatar
Tips for doing it? Would you replace the pump or just the hose? I'm actually not sure how to just change the pulley
Old Jun 22, 2018 | 02:37 PM
CS_AR's Avatar
Let me catch up here. Is it your PS pulley or the crank pulley that is wobbling? Are you seeing any wear on the outer edge of the belt?
Old Jun 22, 2018 | 03:19 PM
Violator's Avatar
Power steering pulley, oddly enough the belt doesn't seem to be worn at all. I recently tried tightening it but using my swivel from underneath made the tensioning bolt want to nudge forward on that bracket it's on and I wasn't sure how tight the belt was supposed to be so I just tightened it as much as I could with a swivel before the bolt got to the point it would come unseated from that bracket. I wasn't sure if it would be more cost and time effective to just replace the pump now (140k on the body 70k on the 3.5 motor unsure if it was replaced or reused)
Old Jun 22, 2018 | 04:40 PM
CS_AR's Avatar
Are you leaking fluid or have a noisy pump?
Old Jun 23, 2018 | 05:38 AM
Violator's Avatar
Actually no, I thought my pump was leaking a little but it's not and I've never had any noise
Old Jun 23, 2018 | 06:31 AM
CS_AR's Avatar
We have:
1) No seal leaks - this tells me the shaft is staying put inside the pump.
2) No noise - this tells me there is no excessive wear on the vanes or fluid delivery problem.
3) A wobbling pulley - the pump has splines the should mate up with same pattern in the pulley to keep this from happening.
If the pulley is wobbling, then I would remove it and inspect the splines to see if somehow the pulley was installed and tightened with a spline mismatch that later worked loose.
Here's a picture of a pump shaft with splines.
Old Jun 23, 2018 | 02:14 PM
Violator's Avatar
We have:
Couldn't get the pulley off while on the car, pulley pullers won't fit in that little space between the wheel well and the pulley
There's a little wear on the crank pulley end of the belt but could that just be from the pulley wobbling?
Old Jun 23, 2018 | 03:44 PM
CS_AR's Avatar
If you have belt wear on the crank pulley edge, is the crank pulley separating? As crank pulleys get older, the rubber damper separates causing the outer pulley belt ring to rub against the power steering belt.
You can see how the one on the right separated and the outer pulley ring is shiny from rubbing against the PS belt.
Old Jun 23, 2018 | 04:07 PM
Violator's Avatar
It's a UDP pulley and I don't believe it has that many miles on it. my first objective is to sort out the power steering pulley issue my air gun doesn't seem to budge the crank pulley and I'll have to go and get a breaker bar
sorry I put this picture on the last post idk what happened. Best pic I could get with the fender/wheel well in the way
Old Jun 23, 2018 | 05:59 PM
Violator's Avatar
Every time I try tightening the belt the tensioner bolt wants to walk off the bracket. The 14mm on the back of the pump wont break loose but does move the entire pump away from or towards the crank pulley tightening/loosening with enough force. After that and tightening the tensioner bolt to the point before it starts to walk off the bracket the belt has 3/8-1/2in of play when I press on it
Edit: pulley isn't wobbling , but squeel still persists. Still not sure the pump should pivot like it did when I tried breaking that 14mm "lock bolt" on the back of the pump, but for now my pulley isn't wobbling so we'll chalk it up to a loose belt as the cause of the wobbling.
Old Jun 26, 2018 | 04:02 PM
Violator's Avatar
My clutch was just glazed, I had no issues with slipping but engaging on lower gears made it squeal. I fixed it by putting on the parking brake revving to 4k and engaging the clutch right to the point of the rpms starting to drop and held it for about 5seconds and afterwards the noise was gone. It's a cheap eBay XTD stage 3 clutch, maybe this will save someone else some trouble in the future.
dillonm695
Feb 21, 2005 08:02 PM
spirilis
Apr 21, 2004 09:41 PM
NismoRacer83
Apr 18, 2002 09:05 PM
emax02
Nov 17, 2000 11:44 AM
