[Help] Front end noise when braking [Videos]
Old May 11, 2018 | 04:20 PM
jchronis2552's Avatar
Hello,
I have recently been having a noise from my front drivers side wheel area when coming to a stop. I have uploaded 2 videos with clear audio. Anybody have any ideas?
Thank you!
James
EDIT: Solved! Front left wheel bearing.
Old May 11, 2018 | 04:29 PM
JvG's Avatar
JvG
Do you also feel pulsation in the brake pedal?
it sounds like you have a warped rotor, or the brake pads are hanging up on the guide pins or sliders.
Does the car pull in one direction when you apply the brake?
Old May 11, 2018 | 04:31 PM
I do feel a little pulsation. It does not pull when breaking. It pulls to the right when driving because I need an alignment.
Old May 11, 2018 | 04:34 PM
As I’m slowing down and take my foot off the brake pedal the noise is still there.
Old May 11, 2018 | 09:13 PM
JvG's Avatar
JvG
Seems like a rotor is warped.
Touch the wheels about halfway to the center. One will be warmer or hotter than the other. That will be the side which needs attention.
Caution.... could be hot to the touch.
Old May 11, 2018 | 09:16 PM
I will be taking it in to be looked at tomorrow. Will post what I find out.
Old May 12, 2018 | 01:41 PM
So, I took it to a shop today but could not get it looked at because my appointment wasn’t confirmed.
However, I wanted to add that the noise is still there even when I’m not braking. It’s there when accelerating, as well as, when slowing down.
Hoping to to get it to a different shop Monday.
Old May 12, 2018 | 01:44 PM
JvG's Avatar
JvG
A warped rotor or a stuck or binding caliper will continue to act up even if you are not using the brake.
Again, does one of the front wheels feel hotter than the other one if you drive the car a while?
Old May 12, 2018 | 01:45 PM
I know the problem is the front left. I did not touch the rim to check temp.
Old May 12, 2018 | 01:58 PM
JvG's Avatar
JvG
You think that you know the location. But you need to confirm your guess. Touch both wheels after driving a few miles. If you are afraid of burns, touch wit wet hands.
I had a rear caliper bind and make grinding noises when I was 200 miles from home. On a Sunday.
So I could trust my luck, or figure out what the problem was. The binding one was almost too hot to touch, while the other side was fairly cool.
I found a binding, stuck caliper after I drove the car home.
Old May 12, 2018 | 07:43 PM
KP11520's Avatar
JvG is giving spot on advice. If neither side gets hot, pull the wheels and see of the inside dust/mud shield has been bent to touch the rotor or the pad slipped or the caliper hardware rotted and left residue somewhere against the rotor.
But not another post until you check the temp of both wheels after driving 20 minutes.
Time for action.
Old May 13, 2018 | 05:38 AM
max ride 41's Avatar
Time for action.
your in the maxima military now son
Old May 13, 2018 | 09:22 AM
KP11520's Avatar
Yeah..... I'm turning into Clint Eastwood in Gran Torino. And Gunny Sgt Friday.
But endless discussion is counter productive. Answers = doing it.
And what does it take to touch your front rims after driving your car?
Old May 13, 2018 | 06:49 PM
JoshG's Avatar
I'd suggest you do not ignore this problem too long...If its when braking, its a message telling you "Hey driver your brakes need attention!" good luck and do come back with what solved the problem.
Old May 14, 2018 | 09:28 AM
agreed, it aint rocket science, it's brakes. as in, you won't have any if you don't do what we as maxima experts tell ya to do.
Old May 14, 2018 | 06:00 PM
Thanks for the input fellas.
The problem was the front left wheel bearing.
Old May 14, 2018 | 07:02 PM
that sounded more like a caliper going bad to me, if that was a wheel bearing, they usually make a constant noise, not a rub noise at braking. weird
Old May 14, 2018 | 07:03 PM
Yep, got it replaced and the noise is gone.. Going for an alignment tomorrow.
Old Apr 8, 2025 | 08:22 AM
Sleepyhawk's Avatar
Thanks for the update. My issue sounds exactly like yours. It was misdiagnosed by a shop, costing me $240.
My car is making the exact same noise.
Majestic
Oct 3, 2008 05:16 PM
99Maxima5sp
Apr 4, 2004 08:23 PM
wickedmax
Dec 23, 2003 05:37 AM
ChrisCheezer
Apr 5, 2002 06:14 PM
kmb
Mar 13, 2002 12:33 PM
