New LED step lights on 4th gen maxima
Old Jun 25, 2018 | 03:20 PM
dbaray's Avatar
Recently bought these. They are a 194 bulb and the stock bulb was a 161. The website claims it can replace a 161 and only draws 1.1 watts. What do u guys think? And is this 194 led ok for replacing a 161bulb??
Old Jun 25, 2018 | 04:26 PM
KP11520's Avatar
So that's where I dropped my condom. LOL
Nice and BRIGHT with the door open. Good call!
Do they have plug and play SUPER Bright Backup Llight bulbs?
Old Jun 25, 2018 | 05:02 PM
dbaray's Avatar
hahaaa 😂 yes they do. Pretty bright for a 194, I like them.
Old Jun 25, 2018 | 07:52 PM
DennisMik's Avatar
Originally Posted by dbaray
Recently bought these. They are a 194 bulb and the stock bulb was a 161. The website claims it can replace a 161 and only draws 1.1 watts. What do u guys think? And is this 194 led ok for replacing a 161 bulb??
yes, it's ok. The original 194 &161 incandescent lamps are different brightnesses from each other. The led is probably brighter than either of the originals. When using an incandescent lamp and going to a brighter one is that you have to deal with more heat in a small enclosure. The heat from a led lamp is much less and is not a problem.
Old Jun 25, 2018 | 09:17 PM
dbaray's Avatar
thanx for the info. Yes i felt a lot less heat from the LED. Good to know. I was picky at forst about this LED and I recommend to people.
Old Jun 25, 2018 | 10:21 PM
CMax03's Avatar
I found that Orielly's extra bright LED for 194, 168 bulb are brighter...Just replaced the courtesy lights and license plate lights with that O'rielly brand....also check out Xtralight.com for an entire interior/exterior LED kit...
Old Jun 25, 2018 | 10:37 PM
dbaray's Avatar
cool ill go check it out 👍🏼 Been needing to replace the license plate light too. And do you know what light size is for the vanity mirror.
Old Jun 26, 2018 | 10:59 AM
CMax03's Avatar
Not sure on those....
Old Jun 27, 2018 | 01:02 AM
DennisMik's Avatar
It is type 6612.
http://www.superbrightleds.com/morei...-30mm-car/243/
If you get these, they will be so bright that you are blinded and cannot use the mirror.
http://www.amazon.com/iJDMTOY-Replac.../dp/B00MOYJ0YW
Old Jun 27, 2018 | 07:07 AM
max ride 41's Avatar
are we trying to help incoming planes land or something? what happened to stealth? i really don't want super bright leds all over my max, seems way overkill imo. now colored led's in the console, doors, etc, different story.
Old Jun 27, 2018 | 09:41 AM
dbaray's Avatar
true true. But yes i dont like the bright led really. I recently replaced the step light. And all the leds in the car are dim. I have a dim map light and back. I just like a different color than a standard bulb haha. But i see your point. I dont like too much light, which is why i have tinted windows lol
Old Jun 27, 2018 | 09:46 AM
dbaray's Avatar
It is type 6612.
thankyou ill check them out. Most likely buy the ones on superbright led 👍🏼
Mike Dee
Dec 8, 2018 08:07 PM
Dayle97SE
Jul 17, 2010 10:04 PM
mist max2000
49
Jun 2, 2010 08:12 PM
jsmithsole
104
Mar 8, 2007 02:42 PM
