4th gen wheel offset??
I'm thinking of getting a 4th gen max and I have some 17x8 Mille Miglia M11-2 Sports sitting in the garage...will they fit? I think they have a 30mm offset. Problem is they are off a BMW 535i (RWD) and RWD wheels usually don't fit FWD cars.
Maximas support bolt pattern 5 x 114 and 18" X 8" rims. The offset should be in the 35-38mm range. Maybe you can fit less then 35mm but I'm not sure. Center bore was not mentioned but if the center bore is too small(smaller then 66.1 mm) the wheels will not fit onto your hubs. You might be able to get different hubcentric rings though.
Originally posted by Chunger
BMW has 5 X 120, plus ET30 would stick out too much... 35 is about as much as you'd want to go.
Maxima_Joe
11-25-2015 08:19 AM
Cant_Get_Ryte
08-28-2015 06:41 AM
