Intake Plenum Gaskets? All the same or which is better?
Old Oct 25, 2018 | 11:50 AM
KP11520's Avatar
Doing the Fuel Injectors, Fuel Pressure Regulator, Injector Insulators, Injector Cushion Rings and fuel hose, clamps and vacuum line.
Plenum Gasket time as well. Any better than and/or offer advantages over the others?
BTW, sad day yesterday.... Rockauto sent an email with a load of closeout parts for 4th Gen Maximas. Our options are slipping away. Rockauto was by far a great friend and source for so many parts at a great price and fair shipping prices.
Probably a good time to get everything right in our Maximas so we can drive them a bunch more mile before we have to resort to Mad Max tactics.
Old Oct 25, 2018 | 11:58 AM
Fakie J Farkerton's Avatar
Go big?
NWP FTW
Old Oct 25, 2018 | 12:10 PM
maximaxi's Avatar
Get the Beck/Arnley plenum gasket. It is the actual OE gasket made in Japan.
Get either Beck/Arnley or Mahle/Victor Reinz valve cover gaskets. Again, they are the actual OE gaskets with the actual OE spark plug tube seals, made in Japan.
Also clean out the EGR guide tube, and get those gaskets, too. Again, the same two brands are the actual OE gaskets.made in Japan. If cleaning out the EGR guide tube turns out to be difficult or impossible due to it being too clogged, you can still buy a brand new EGR tube from the dealer. It is about $40.
Old Oct 25, 2018 | 12:56 PM
JvG's Avatar
JvG
I used the fel-pro gasket set.
Quality was fine, as usual for them.
Old Oct 25, 2018 | 01:44 PM
reallywildstuff's Avatar
I did this earlier this year and left my notes here:
https://maxima.org/forums/4th-genera...e-exhaust.html
Old Oct 25, 2018 | 03:15 PM
KP11520's Avatar
Originally Posted by Fakie J Farkerton
Go big?
NWP FTW
That's not Big! That's HHHUUUUUGE!
Old Oct 25, 2018 | 03:17 PM
KP11520's Avatar
So Gentlemen, Thank you all for responding! And RWS, thanks for all that info!
So I see the Mahle is rubber. Are they all rubber and is that good?
Thanks again!
Old Oct 25, 2018 | 03:43 PM
JvG's Avatar
JvG
Fel pto is also rubber
Old Oct 26, 2018 | 06:48 PM
vqmaxman's Avatar
I have talked to the dealerships and other aftermarkets out there, it seems like the parts for the 4thgen getting scarcer due to not only because of age but more likely someone or some party that's wanting to put a stop out there for the maxima community. I have seen honda guys as old as early late 88,90 models civics ect are getting mad aftermarket support. I had some headers i have ordered for my car they cleaned house and fudged my onky headers. To top it off they don't produce the headers anymore now. Thanks to some person with some powers to put a stop to the aftermarket support on maximas. I will tell you this from experience and spending time and hours with manzo and megan and other aftermarket support. I can't even for gods sakes get a rear inner brake tales from courtesy nissan. They say they still have stuff for the car.
Old Oct 26, 2018 | 08:35 PM
Originally Posted by vqmaxman
I have talked to the dealerships and other aftermarkets out there, it seems like the parts for the 4thgen getting scarcer due to not only because of age but more likely someone or some party that's wanting to put a stop out there for the maxima community...
Thanks to some person with some powers to put a stop to the aftermarket support on maximas. I will tell you this from experience...
Old Oct 26, 2018 | 10:49 PM
vqmaxman's Avatar
[QUOTE=Fakie J Farkerton;9186330]
Lol......The only thing you got to do is go to the websites that i have listed and call and ask for some parts or a couple of things needed they will tell what i am telling in the post.
Old Oct 27, 2018 | 07:54 AM
CS_AR's Avatar
Fel-pro only for the last three 4th gen restoratations. I'm not sure what I used on the I30. Most likely Beck or OEM so some combination of that. About the time I switched to Fel-pro I started using Permatex black for VC gasket corners and got better results. I like sticking with the same supplier when a product works.
Old Oct 27, 2018 | 01:25 PM
KP11520's Avatar
In case anybody is interested, Rockauto has the Fel-Pro and Mahle Plenum gaskets for less than $4.00 until they're gone. I'm going to buy a couple.
Old Oct 27, 2018 | 02:26 PM
CS_AR's Avatar
Oh no.. I know what that means.. I see 5th gens have replace 4th gens in popularity at the salvage yard. Not good..
Old Oct 27, 2018 | 09:48 PM
sb001's Avatar
Or you could just not worry about any of this stuff at all and still get over 400k miles out of your Maxima like I did.
Old Oct 27, 2018 | 10:19 PM
max ride 41's Avatar
but, you got rid of your 4th gen and are looking at a 5th gen.....
Old Oct 28, 2018 | 02:17 AM
sb001's Avatar
That doesn't change the fact that my 4th gen had over 400k miles on it when I sold it and was still running like a top without me ever having to change any of the gaskets mentioned previously in this thread.
Perhaps you should explain the point of your statement.
Old Oct 28, 2018 | 10:30 PM
gladly, if it was running so flawlessly why did you sell it? i mean, high mileage and all i would've kept it unless there were some outlying problems with it. it looked clean, hell, i would've swapped another vq into it and kept her another 5 years, just sayin.
cguzman
Jul 18, 2022 09:22 AM
edwardh1
May 9, 2018 04:16 PM
alperry360
Apr 9, 2014 06:26 AM
porshapower928
Feb 11, 2009 08:10 PM
maxima1239
Apr 4, 2008 05:18 PM
