Dash and right tail light fuse keeps blowing
As the title says, 7.5A fuse of dash and right tail lights on my 95 keeps blowing randomly -sometimes the very second I turn on the light, sometimes suddenly when lights are on for a few minutes-. I've tried to disconnect the dimmer switch as I read in other forum. Also, I've changed the cluster and I've replace the tail light bulb, but the problem persists. Any suggestion of what should I check next?
This may be a hard one to fix. A wire is shorting out somewhere and grounding. You have to find the loose/bare wire and tape it to prevent it from grounding (touching bare metal).
Think back, have you done any work to the car just before this problem started?
The only work I've made regarding electrical components is changing the cluster. I checked the connectors BTW but I didn't find anything strage there.
PS: This car also has the typicial non-working cluster issue so I bought another one some time ago trying to fix that. I assume both problems are not related to each other.
I would try the easy stuff first.
let's start with the tail light. Remove it. Look in the socket for any corrosion. Clean any corrosion you find. Next, leave the tail light out. Do the things which make the fuse blow. Does it still blow?
If not, put the bulb back in to see if things work properly.
Well, I think problem has been solved. It was a freaking bolt from the cluster wich I missed behind the dashboard some time ago -I didn't care too much about it then-. It was probably touching one of the wires under the steering column
You mentioned that you changed the tail light.
I'd be more suspicious of the socket it's self.
I would clean that with contact cleaner. I'd examine the wiring at that socket carefully as well.
I've had this very issue on three cars I've had in the past.
I agree that the fuse is blowing due to a short somewhere between the tail light and the cluster.
akurtzer57
Apr 12, 2014 02:53 AM
. Any advice on how to start looking for the short? I've never done any work like this before.
