Best “OEM” Manual Transmission Clutch Kit?
Old Nov 16, 2018 | 11:54 AM
4thGenTimeWarp's Avatar
I am replacing the clutch kit in my transmission as I replace the transmission. What are your recommendations for an OEM- or slightly better- clutch kit?
Any kits that I should stay away from other than the obvious Autozone/Duralast stuff?
Old Nov 16, 2018 | 01:57 PM
Fakie J Farkerton's Avatar
Use exedy
\thread
Old Nov 16, 2018 | 02:01 PM
I have a stage three Exedy in my other car and it compliments that vehicle well/minimizes high RPM lockout greatly. I just figured even a stage one Exedy would be overkill on a Maxima. What are your observed benefits over the stock part clutch performance?
Old Nov 16, 2018 | 02:08 PM
Exedy is OEM
Different stages=more torque it can handle
Old Nov 16, 2018 | 05:50 PM
CS_AR's Avatar
Whenever you buy a clutch kit, check the smoothness of the throw out bearing. I opened and check three different clutch kits from name parts stores before I decided to go with a National throw out bearing. There was a clear difference in the smoothness of National bearing. So I bought it and tossed the kit bearing.
One of the best things you can do to improve clutch feel it to replace the stock line (and junction box) with a stainless.
Old Nov 16, 2018 | 06:02 PM
Zerodrag's Avatar
Not to threadjack, but what recommendations are there for a performance clutch (SCed) with light pedal pressure? The one I am currently using is heavy and a pain to use in high traffic situations.
Old Nov 16, 2018 | 07:33 PM
RA030726's Avatar
I'm nutty for Nissans
Exedy stage 1 has the same pedal feel as stock.
Old Nov 21, 2018 | 01:45 PM
Now just to get the other transmission on....
Old Nov 21, 2018 | 04:45 PM
CS_AR's Avatar
BE SURE TO CLEAN AND SAND BELL HOUSING AND TRANSMISSION MATING SURFACE. That is a major source of the engine ground. You don't want to create a grounding issue that causes you to rework the transmission installation.
Old Nov 24, 2018 | 05:25 PM
CR7's Avatar
CR7
Definitely exedy. Just replaced mine couple of months ago and put on about 2k miles on it so far. Absolutely love it. Same oem pressure feel.
puremax
Feb 3, 2009 06:31 AM
Jonny98max
Nov 17, 2004 02:43 PM
Ladzio
May 4, 2004 03:50 AM
SuperFishstick
Oct 9, 2003 04:35 PM
triax37
Sep 29, 2002 03:59 PM
