'99 A/T Flywheel Inspection Plate?
Old Jan 15, 2019 | 07:29 AM
Turbobink's Avatar
Apologies for the question if it’s a no-brainer but I’ve not been able to find any specific info. in the FSM, my Haynes manual or via google and I haven’t been under the car since deciding I want to do a flywheel/drive plate inspection.
Q: In our A/Ts, is there an inspection plate that can be easily removed so that the teeth on our flywheel/drive plate can be inspected?
I had an odd long term periodic starting blip/glitch/burp that recently culminated in a starter failure that included what I’m confident was the full gnashing of starter gear teeth against drive plate teeth.
The starter was replaced with a new one this past weekend but the gnashing continues and I’m concerned that perhaps my drive plate has been damaged.
I’d like to have a look at it from a larger perspective than just through the starter orifice (which revealed no damaged from what I'm able to see) but without dropping the transmission.
Old Jan 15, 2019 | 10:39 AM
schmellyfart's Avatar
Yes
Old Jan 15, 2019 | 12:21 PM
CS_AR's Avatar
IIRC - Two 10mm bolts are used to secure it. Looks like a good time to clean the rear crank sensor of any metal shavings.
Old Jan 15, 2019 | 02:18 PM
Turbobink's Avatar
Originally Posted by CS_AR
... Looks like a good time to clean the rear crank sensor of any metal shavings.
If’n it wasn’t brand new Craig, I’d agree with you.
Boy I’m sure hoping I don’t find any uglies in there.
Nismonieves
Apr 13, 2013 10:44 AM
k20tek
41
Jul 14, 2009 09:09 AM
PHAT6
Aug 15, 2006 08:39 PM
MONSTERMAX
Jun 8, 2005 01:34 PM
May 12, 2003 08:56 PM
