so i've tried EVERYTHING, car still smokes at start up
Old Mar 4, 2019 | 09:26 PM
max ride 41's Avatar
as stated, new cat seemed to help at first, but i started up the max today and still have tons of smoke and fuel smell. i got a code for an iacv ( 0505 ) and cleared it, but with all the issues i had and i know the plugs are still going to be black. i have a intermotor iacv, only about 10 months old, second one to throw a code in less than a year. i got an oem one from ebay for cheap, wanted to see if she'd run better with that rather than the aftermarket one. i know she's been sitting for a week, and the colder air and all the dampness makes her run even worse. i still so stumped on this running issue i'm ready to give up, ideas? ask any questions, no codes, after she warms up the smoke goes away, but returns after she sits for an hour or 2. i'm so completely frustrated, halp.
Old Mar 4, 2019 | 11:22 PM
JvG's Avatar
JvG
Sorry if this has been brought up before.
Status of fuel injectors?
Old Mar 5, 2019 | 04:03 AM
MadMax07SL's Avatar
What color is the smoke? All that detail and you left that out. Do you think it's just unburned fuels? I'd think if this were worst case, you have valves sticking open, engine seals, head gasket, something serious is likely causing this, considering it seems you've troubleshot it from the outside for a bit now...
Old Mar 5, 2019 | 04:13 AM
JoshG's Avatar
Some of your fuel injectors are stuck open. Even though u may of have replaced them, they could be stuck open...
Old Mar 5, 2019 | 04:36 AM
Turbobink's Avatar
Perhaps you're MAF hasn't been properly cleaned
All kidding aside ... as I recall several, if not a number, of members have urged you to look in the direction of the injectors ... and we still urge you to look in that direction.
Your symptoms are classic.
Old Mar 5, 2019 | 04:54 AM
when i get the $$$$ and the time and it warms up, i'm going to pull the front 3 injectors and see what they look like. 2 are about 2 years old and one is 12 months old. the 3 in the rear are 10 months old and were put in together. coils are new, compression was checked and i had one cylinder that was a little lower than the rest, leak down test maybe?? why does the iacv keep throwing a code?
Old Mar 5, 2019 | 05:20 AM
krismax's Avatar
Father of the 00 VI
Have you checked your IM it's probably filled with oil. And have you changed your PCV lately?
Old Mar 5, 2019 | 05:41 AM
Violator's Avatar
Fuel smell it smells like fuel only happens at start up and some time later could be something with the evap. This systems opens and closes and I'm pretty sure affects cold starts. I'd say definitely run some fuel injector cleaner if you haven't
If it's not evap or injectors I'd be surprised you're not throwing a code for whatever it is
Old Mar 5, 2019 | 06:57 AM
no codes, and i can't think what the im is krismax, pcv valve is new. new fpr, new 02's, new crank sensor, coils, plugs. new intake and valve cover seals, no vacuum leaks, would a charcoal canister stop working and not throw a code? what about that valve in front of it? check in later---
Old Mar 5, 2019 | 07:16 AM
Zerodrag's Avatar
I forgot if you've already checked or replaced, but how about the coolant temp sensor? Long shot but something to consider it haven't already.
Old Mar 5, 2019 | 08:18 AM
Turbobink's Avatar
no codes, and i can't think what the im is krismax...
Intake Manifold ...
Old Mar 5, 2019 | 11:29 AM
Shrout1's Avatar
My '12 Mustang was running like hot garbage after I filled it up and it turned out to be an evap canister issue. Could lead to a fuel smell...
Old Mar 5, 2019 | 02:20 PM
Zerodrag's Avatar
If the smell is a raw fuel smell, and your gas tank is pretty full, there is the possibility that it could be that the fuel sending level unit having a crack on the plastic top. This happened to me and I had found it only through an old forum post. the smell would only show up when the tank was filled and the car had been running. It disappears after sitting for awhile probably due to loss of pressure in the tank and evaporation of fuel that got pushed out. this would not explain the smoke coming out of your exhaust though.
Old Mar 5, 2019 | 09:12 PM
Intake Manifold ...
new upper and lower gaskets. no code for coolant temp sensor. that was bad 14 years ago and i had the dealer replace it.
Deac
Jul 9, 2016 04:59 PM
SRTuLTR
35
Dec 12, 2014 02:26 PM
wish2345
Mar 12, 2011 09:10 AM
madd_maxx
52
Apr 12, 2010 09:28 AM
WhiteA32
Mar 6, 2009 09:36 AM
