driving without power steering
Old Jun 22, 2019 | 01:58 PM
plat's Avatar
The power steering belt has suddenly starting squealing, slipping and burning. It was inspected two weeks ago and found to be in good shape so this is a sudden failure. If it turns out to be the pump failing/seizing up then I am thinking about just not fixing it.
Has anyone driven their Max long term without power steering?
I just want to know if it would be totally intolerable or if you got used to it. When the shop calls me up in a few hours I will have to tell them whether to fix it or not.
I mainly want them to make sure that there isn't an issue with the crank pulley because of course that must be fixed asap.
I just dropped big bucks doing the MAF and IACV two weeks ago so the thought of replacing the pump is making me sick at the moment.
Old Jun 22, 2019 | 02:05 PM
JvG's Avatar
JvG
You could buy a perfectly good used pump at your local wrecking yard for a reasonable price.
Why on earth would you consider using the
Armstrong Method instead?
I was in the same situation with a different car a long time ago. The shop ordered one from a jy and installed it for a reasonable price.
Old Jun 23, 2019 | 12:31 AM
User1's Avatar
Man up. I had a 1970 Chevy C10 long bed fleetside lowrider hot rod truck that I built over time when I was 16. I muscled that thing around with no power steering and a small diameter Grant steering wheel daily for two years. Probably some of the most fun I've had in a vehicle. Those were the days.
Old Jun 23, 2019 | 04:28 AM
Turbobink's Avatar
Realize though, that those “manual” steering systems of the past were built around ratios and with geometry that made them usable.
A power steering system is designed as and to operated as a hydraulic system.
With a nonfunctioning power system, you’re also fighting non-pressurized/non-flowing hydraulic fluid.
Fix your power system.
IAMALI1
71
Mar 18, 2016 07:10 PM
speed racer
Jul 5, 2013 05:06 AM
rblower2012
Mar 11, 2013 05:03 PM
2da mizzax
Dec 11, 2006 10:05 AM
ericdwong
Oct 8, 2001 12:04 AM
