Z32 BBK front lines
Old Aug 7, 2019 | 09:57 AM
GRNMAXDMON's Avatar
Z32 BBK front lines
Ok guys, need your help on this. What brake lines are you guys using for your Z32 BBK? my front hose popped and now I need to know if the 240SX brake hose for the Z32 upgrade will fit our maximas? thanks in advance.
Old Aug 7, 2019 | 10:12 AM
Turbobink's Avatar
Although I don't see one in your signature photos or read one listed in your signature, based on you're having posted in the 4th Gen sub-forum, I'm assuming you're wanting to replace the lines on a 4th Gen.
That being the case, what's wrong with replacing with Maxima/A32 OE replacement lines?
Old Aug 7, 2019 | 10:33 AM
RA030726's Avatar
I'm nutty for Nissans
LOL
The calipers have a different fitting so GRNMAXDMON can't slap on stock parts and call it good.
Old Aug 7, 2019 | 10:38 AM
GRNMAXDMON's Avatar
Exactly what JSutter posted. Need to see what all else you 4th gen guys are using. Im trying to replace my lines in my 3rd gen. Thanks JSutter for posting it on here. Basically what I need to know is if the thread on the hardline coming from the body is the same as other Nissans? I know the line does not have the banjo fitting as the Z32 calipers do not have a banjo bolt. So that's why I am also asking in here.
Old Aug 7, 2019 | 03:59 PM
RA030726's Avatar
According to Blemco's ads they fit 89-03, so the lines should be the same. He also stated they are, "Goodridge Stainless Steel brake lines, certified to D.O.T. FMVSS test 106 (many of the brake kits out there don’t have this)."
Try contacting Goodridge and see if they have the specs for said lines.
Old Aug 7, 2019 | 06:20 PM
S13 conversion lines are fine.
Maximan190
Jan 18, 2010 06:03 AM
mad-max98
Sep 19, 2005 08:08 PM
Nismo
Aug 12, 2005 05:16 PM
jblinga
Jan 6, 2005 01:06 PM
