Oil light flicker twice on every start ups
Old Sep 25, 2019 | 04:53 AM
speedlover's Avatar
I changed the oil pressure switch and yes its from the dealer and the problem is still there. Yet the oil level is good and no metallic sounds that engines make when they don't get oil. It runs fine no smoke no nothing. Its a 98 with 72000 miles. Has anyone have this problem and still drove it like that for years or so? Need help and advice
Old Sep 25, 2019 | 07:25 AM
Turbobink's Avatar
I'm not sure that the "flickering" of the dash indicator on startup ... while oil pressure builds ... is a problem.
Old Sep 25, 2019 | 09:04 AM
Lethal's Avatar
My 98' does the same thing. Has done it since I've owned it. I don't think its an issue.
Old Sep 25, 2019 | 10:40 AM
DizzyEdge's Avatar
What does that mean?
Same with my '96.
Old Sep 25, 2019 | 12:18 PM
Maxima 97 SE's Avatar
Crappy oil filters will cause this problem. You have to use the oem nissan one from the dealership or use the bosch ones. I have never had a problem with that light again.
Old Sep 25, 2019 | 12:43 PM
vingodine's Avatar
Its normal.
My 3.0 and 3.5 do the same thing at startup.
Now if it flickers after your warmed up and while your driving than you may have some other issues.
My car when driving would flicker only when i was really low on oil or if i was to come to a hard stop which would cause oil in pan to woosh around briefly.
Old Sep 25, 2019 | 12:47 PM
01bluemax's Avatar
My 01 used to do it and my 00 does it too. Nothing to worry about as long as the light doesn't stay on.
Old Sep 25, 2019 | 03:42 PM
DizzyEdge's Avatar
Interesting, I'll grab an OE filter next oil change.
Old Sep 25, 2019 | 06:26 PM
JoshG's Avatar
Now if it flickered on after a 10-minute drive and start hearing knocking sounds... too late. But otherwise on startup, it shouldn't be a problem, all the oil has to build up from the bottom.
Old Sep 27, 2019 | 09:46 PM
It's also an indication of weather your idle is low or you don't have enough fuel pressure when starting the car causing the car to stall or idle low.
Old Sep 28, 2019 | 03:27 PM
max ride 41's Avatar
my oil light has flickered for 14 years, oil was low a bunch of times and no worries. not like my pos hyundai that went 3 quarts low with no warning and i had to replace the engine.
Old Sep 28, 2019 | 06:35 PM
JoshG's Avatar
Goes to show how well built these 4th gens were made. Every car is built differently. Some are weak like fiat's, some are bulletproof.
Old Sep 29, 2019 | 06:11 AM
sdunker's Avatar
I have had a 96, 97 and a 98. None of them have displayed a flickering oil light at startup.
Boothers96
May 22, 2012 05:21 PM
Max_Gator
23
Apr 9, 2007 12:21 PM
busterdawg22
May 29, 2006 10:34 AM
Kta920
20
Sep 1, 2004 05:23 PM
MaximaRacer
Jan 15, 2002 10:11 AM
