Spare tire / lug nut and stud woes
Old Nov 8, 2019 | 01:52 PM
reallywildstuff's Avatar
98 i30
128k
Yesterday I had a flat, passenger rear. I replaced it with the spare No Problem - tightened the factory closed-end nuts with the wheel on the ground and the factory wrench.
Long story short - to replace with new tires, my “known quantity favorite trusted shop” had to chisel 4 out of 5 nuts off...the favored mechanic said “these Jap cars, I dont know...the lug nuts just go bad, it wasnt anything you did necessarily”
Guys, there is no way I cross-threaded or overtightened (with my body only) 4 out 5 nuts/studs. I wasnt in that much of a hurry, and everything felt real good...
WTF over. Is this some common malady that has heretofore escaped my notice on this board?
Old Nov 8, 2019 | 02:11 PM
RA030726's Avatar
I'm nutty for Nissans
The steel wheel is thinner and perhaps the deeper threads in the lug nuts were damaged for one reason or another and then they ruined the studs.
Old Nov 8, 2019 | 04:52 PM
Pics
Attached Thumbnails Spare tire / lug nut and stud woes-b0f188bf-7f74-4c3b-8be3-047ea7ad76c5.jpeg   Spare tire / lug nut and stud woes-141d7877-1b7a-4735-a7cd-88353b87466b.jpeg   Spare tire / lug nut and stud woes-6ba02677-2d70-4034-ba43-2b91024248d4.jpeg   Spare tire / lug nut and stud woes-c08480c1-c45f-41f3-a2fe-b39c55fbfd1d.jpeg   Spare tire / lug nut and stud woes-922d56e6-88e0-46e5-8261-52f228ec2817.jpeg
Spare tire / lug nut and stud woes-13a1fa81-5bdd-43fd-be88-09f81dac1587.jpeg
Old Nov 8, 2019 | 07:52 PM
RA030726's Avatar
Is the bore on the spare supposed to be bigger than the hub? Seem strange to me.
Old Nov 9, 2019 | 09:37 AM
KP11520's Avatar
New rear OEM studs are on eBay or at the dealer. $2 to $3 each. Make sure you find where there's enough clearance to remove fully and bang them out with a hammer. To install new, get a heavy duty nut the thread size of the stud and add 4 or 5 thick washers and slowly pull the stud back into the hub until it's bedded if the studs got damaged.
I replaced all 10 in my front hubs and got all new acorn lug nuts. SOLID lug nuts. Amazon has 20 lug kits for reasonable.
And the OEM nuts with the studs shouldn't cause problems when threaded all the way on with no wheel. I've never had any problems when locking the rotors to the hubs when doing associated work.
And if you overtighten lug nuts, they are supposed to be softer than the studs and that's where the threads fail because it's easier to replace a lug nut than a stud. So maybe goosed 'em a bit much over the years and that flat was their last stand.
Tommy6905
21
Feb 19, 2014 05:11 AM
2brosgixxer
20
Aug 25, 2013 12:04 PM
Digger01
Sep 18, 2007 11:02 AM
99seCALIforniCATer
Jan 6, 2007 04:33 PM
Noela
Oct 11, 2004 01:32 PM
