Burning smell from using the heater
Old Dec 15, 2019 | 02:20 AM
speedlover's Avatar
For some reason i smell something burning when my heater gets hot enough but its not overly strong smell since at times when im driving i don't smell it. I look under the hood i don't see nor smell anything burning. Not leaking oil still have the original gaskets i think since my car have 73000 miles. What could this be? This happened every day since im using the heater.
Old Dec 15, 2019 | 03:57 AM
Turbobink's Avatar
Smells like burning what ... yard trash, tires, roadkill, coolant, motor oil, what?
Old Dec 15, 2019 | 05:47 AM
max ride 41's Avatar
Smells like burning what ... yard trash, tires, roadkill coolant, motor oil, what?
BACON, I SMELL BACON!!!!!
Old Dec 15, 2019 | 05:51 AM
speedlover's Avatar
Like rubber/oil burning
Old Dec 15, 2019 | 06:43 AM
Turbobink's Avatar
When this smell is present, have you inspected the e-compartment?
Is the smell present in the e-compartment also or is it only inside the car?
Old Dec 15, 2019 | 06:52 PM
JvG's Avatar
JvG
Are you adding oil more often than in the past?
Old Dec 23, 2019 | 01:58 AM
speedlover's Avatar
Only in the car and the smell goes away a bit when driving on the highway but if u smell really hard u could smell the burning odor. Idk wat to do besides just live with it since its about to be 23 yr old car. Plus don't have the money to really fix the car. It runs fine tho
Old Dec 23, 2019 | 02:02 AM
speedlover's Avatar
I might think it could be the wires since the last owner mess up the center console to install a crappy aftermarket radio with back up camera ghat dont work
Old Dec 24, 2019 | 12:08 AM
anythings possible, maybe pull the head unit and see if everything's connected properly.
Old Dec 27, 2019 | 07:38 PM
JvG's Avatar
JvG
The source is either from under the hood or in the dashboard.
One of the heater buttons is a fresh air or recirculating button.
press the button to recirculate the air.
If the smell goes away, the source is under the hood, and most likely from a leaking valve cover.
if the smell persists, it's most likely from the dashboard, and related to the stereo.
T93Max
Dec 15, 2006 09:15 AM
proguitar04
Jan 9, 2004 02:59 PM
XeroX
Dec 30, 2003 10:51 AM
RichMax
Jun 7, 2003 08:51 AM
blizz20oma
Dec 18, 2002 07:40 AM
