weird noise when turning, not cv joints...help?
the noise is a very slight grinding/rubbing noise that occurs when turning, doesn't matter if im stopped or moving, same noise...i figured it was the cv joints, so i had someone turn the wheel while parked as i got under each wheel, but i could not hear the noise from near either wheel, even though it can be heard from the cabin...any ideas as to what it might be?
Re: weird noise when turning, not cv joints...help?
I was getting something similar at low speeds, like when parking. I think I've concluded that it was the tire rubbing against a plastic shroud like thingie which is on the inside of the wheel well. I bent them back a little and it seems to have cured it.
Just a suggestion.
Just a suggestion.
pears
09-18-2015 05:25 AM
lrb6805
09-17-2015 04:49 PM
