Seatbelt light does not come on
Old Jun 3, 2020 | 08:49 PM
aembleton's Avatar
Hey all,
So my seatbelt light doesnt come on when I turn the car on, no chime or light when the belt is released. I replaced the lights in the cluster and still no luck. This is in my 97 i30 my maxima works as intended.
Any thoughts?
Old Jun 3, 2020 | 10:28 PM
JvG's Avatar
JvG
Originally Posted by aembleton
Hey all,
Any thoughts?
First of all....
Does this even matter?
I could understand if you have small children in the back seat
One or two adults in the front seat don't need a nanny light.
Old Jun 3, 2020 | 11:49 PM
98 i30t 5spd's Avatar
Hey all,
Any thoughts?
Try a different bulb, the replacement bulb could have also been bad. Also, on this particular car, there isn’t any seat belt chime. The light is simply on or off.
Old Jun 4, 2020 | 03:34 AM
dsonnylal's Avatar
This happens in my car as well. To get the light to illuminate I press the red release button for the seat belt on the buckle (driver seat) a couple times without the seatbelt being inserted.
hope that helps
Old Jun 4, 2020 | 02:58 PM
aembleton's Avatar
Originally Posted by JvG
First of all....
Your right it doesn't matter but I was curious if it was a common issue
Old Jun 5, 2020 | 12:29 AM
JvG's Avatar
JvG
Perhaps some one who has dealt with this issue can tell us the real answer. I honestly don't know.
My car has a mystery issue. A light is supposed to light up when the car is low on fuel. Mine quit. It started being not accurate before it quit. I imagine that the light will work again if and when the fuel pump needs to be replaced. I just live with the problem because fixing it will be a pita.
Such is life with an elderly car.
Old Jun 5, 2020 | 07:13 AM
RA030726's Avatar
I'm nutty for Nissans
Did you check if the wiring for the latch is plugged in?
Old Jun 5, 2020 | 04:03 PM
aembleton's Avatar
No not yet I will do that
Old Jun 5, 2020 | 04:04 PM
aembleton's Avatar
I believe the fuel light is controlled by the wiring harness on the fuel sender, mine was intermittent years ago and then began to work again
MattB85
Mar 25, 2008 02:53 PM
walshy
36
Jul 21, 2005 06:28 AM
HarrisH
Apr 17, 2003 03:31 PM
