Injector O-ring Failure.. Pics inside.
What's Up .Org
I had a 4th gen in the other day, that was towed into the shop with a Hydro locked engine and smelled of gas horribly. I suspected the injector lower o-ring had dropped. However the root cause is either a loose, cracked or just cheaply made pintle cap. That cap technically is all that's keeping this show together.😂
Needless to say the customer installed eBay injectors 4 days prior and they had to go. The 4thgen is back up and running. I thought I would just share what I found being 4th gen related. Im not sure of any pictures of this ever being posted. Most would suspect when the forum reads "leaking injector" that its leaking at its port.. But , Side feeds can also leak around the Body.. ✌
Travelor
12-26-2013 10:15 PM
