96 GXE 5 speed small transmission leak
Recently my maxima has developed a small leak along the seam of the transmission. Isnt too bad at the moment (only a 5 inch by 5 inch puddle under the transmission after sitting for two day, it didnt even look fresh) but Im not sure what to do. I dont want to take it into the shop and have them tell me the gaskets or seals will need to be replaced for something that is fairly minor. Ive seen that gasket restorer stuff that you pour into the oil and transmission fluid thats supposed to swell and enlarge the gaskets to help with leaks. Is that stuff any good? Im just scared that the problem will get worse the more I drive it and will lead to bigger problems down the road.
1. Is it looking oil or trans fluid. Oil would suggest rear main or upper oil gasket. If you do a clutch replacement you could replace them if they are leaking
I would not pour that stuff in the transmission. Yes it may be a temp fix but that stuff is hard to get rid of when you dont want it. It could also mess something up.
Could possibly be rear main seal leaking or axle seal they are relatively close to each other so it can be confusing. To find out for sure, they both have different smells. Tranny fluid will smell like cat pee lol and be a clear yellowish brownish color to it and also be thick.
Turbobink
Nov 17, 2008 02:46 PM
