project vids: radiator, harmonic balancer, speakers, brakes, axels, caliper, hvac!
SubscribeAfter I posted this thread: https://maxima.org/forums/4th-genera...n-failure.html detailing many of the failures with my 1999 Maxima GLE (which even a commercial mechanic told wasn't worth sinking money into), my wonderful neighbor undertook the car as a project. The original thread videos are his, and they have been so informative to me that I thought I'd post links to the many vids he has/is making to refurbish the car for anyone else's reference.
There are a lot, and I might update as he does more on subject including:
key loop repair, de-greasing engine, vertical hood positioning, cam position sensor, cooling fans/shroud removal, radiator install, cooling fan testing, knock sensor replacement, axles, breaks, oil, break and steer fluid extraction, brake discs, oil filter prep, battery drain measured, door moulding repair, harmonic balancer, power steering belt, alternator belt tensioner, rear brake removal, caliper reset, testing Bose speakers, painting rims, axle comparison/transfer/dust shields, CV axle install, caliper glide pin service, crowbar camber setup, hvac flap actuator and battery tray, air box and upper intake removal.
more links in a continued post below
Hey great video's the guy is really good explainer of things ... I have a question would this guy do a video on replacing the ABS computer and Master brake cylinder ? My ABS light came on and I think it is the damn computer itself not just a speed sensor .. Curious to see how one would go about replacing the ABS control module computer which I think sits under the Master brake on the firewall side could be wrong.
