AC compressor replacement requires new condenser?
Old May 19, 2022 | 01:21 PM
bigd480's Avatar
If my 4th gen's AC went out from sitting too long (not a failure while driving, refrigerant/oil leaked out and it no longer holds pressure) does it need to have the condenser replaced when the compressor is replaced?
One auto AC expert I talked to said you have to do the condenser at same time and my usual mechanic says just replacing the compressor/dryer is fine. Car has about 245k miles.
Also is there a recommended place to get the parts? Was looking at this kit from RockAuto: https://www.rockauto.com/en/moreinfo...11443&pt=17507
Old May 19, 2022 | 01:51 PM
RA030726's Avatar
I'm nutty for Nissans
Where is the leak?
Some driers are built-in to the condenser so the AC expert isn't exactly wrong. On a 4th gen however, the drier is a separate part so no need to replace the condenser. The local stores have the drier for about $20-25.
Old May 19, 2022 | 02:01 PM
bigd480's Avatar
Yes was going to definitely do the dryer/compressor
The leak seemed to be at the compressor itself, car wasn't used for a couple months early during the pandemic, there was a pool of what didn't seem to be motor oil under the compressor, and then the AC didn't work.
Condenser itself is really reasonably priced as part of the kit - will go ahead since original is so old anyway.
Rob L. Cook
Jul 19, 2017 05:34 AM
comrade_Charlie
Jun 5, 2009 12:29 AM
VQuick
20
Aug 10, 2008 03:33 PM
CraigsMax01
21
Jun 27, 2008 05:48 PM
CSP
Jul 11, 2006 03:22 PM
