TPS after replacement, slight loss of power
Old Jun 11, 2022 | 02:27 PM
James Davis's Avatar
Hey guys,
Second post here, Im currently having an issue with my 97'. Just recently she has obtained a slight loss of power when pressing the acceleration pedal.
The last issue I had was puttering when driving, no issues at idle. I replaced the TPS and the car has been working wonderfully up until recently.
Ive recently replaced the fuel pump, fuel filter, mass airflow sensor (3rd party manufacture) and TPS (from junk yard) and cleaned the throttle body, ECG valve and cleaned the Intake manifold. I also use premium.
I was wondering what I should check first? Should I try to tighten the TPS to increase the idle RPMS to give it that little boost?
or is it really nothing to worry about? Ive only noticed once when idling that the rpms will drop just about to where it wants to shut off.
Old Jun 12, 2022 | 09:50 AM
JvG's Avatar
JvG
Have you cleaned the IACV
Idle Air Control Valve.
It's function is to provide air for idling while the main throttle valve is closed.
Old Jun 13, 2022 | 03:56 AM
Turbobink's Avatar
After the TPS was replaced was it properly adjusted?
if it was adjusted, was it adjusted while the motor was at normal operating temperature?
caseymaxima
22
Aug 5, 2018 11:29 AM
PearceYaussy
Dec 29, 2016 04:05 PM
mb76pl
Dec 3, 2016 10:30 AM
hrobins
Nov 28, 2015 09:49 AM
hornepirate
Oct 21, 2013 03:47 PM
