Parts checklist help
Old 06-26-2022, 01:08 AM
fattmaxx02's Avatar
I am about to endure the task and cost of doing some much needed trans,..ac, and oil leak maintenance to my 1995 se 5spd with 115k miles. Main problems are the clutch is gone due to long term rms oil leak, ac is out due to evap core. I'm going to be replacing quite a few parts and was asking the community for help with any parts I'm missing or should replace while in there..... (Parts I have).... new clutch, t.o. bearing, flywheel, evap core, both ac hoses/ lines, dryer, expansion valve, and o ring kit..(The parts I have to order).. are the oem master and slave cylinders, oem flywheel bolts, stainless steel clutch line, cv axles, redline mt90, oem axle seals, oem rear main seal assembly thingy, half moons for upper oil pan, ac compressor ( the one for early 95), ac oil, condenser, andheater hoses/ clamps. Also replacing subframe and engine/trans mounts/ bush with poly. Any advice on additional parts to repair/ replace please chime in. Thanks.
fattmaxx02 is offline
nicks79
04-07-2007 02:17 PM
Tarzan
09-01-2005 07:42 AM
PoKKi
07-16-2005 07:01 PM
bvtran
05-02-2005 11:26 AM
Quick Reply: Parts checklist help
