Shim Specifications Layout
Old Oct 29, 2023 | 08:38 PM
Leogane's Avatar
Hi All,
I need a diagram of the thickness of every shim on a 1995 maxima.
Old Oct 30, 2023 | 04:10 AM
Turbobink's Avatar
I’m thinking that a bit more specificity might help.
Old Oct 30, 2023 | 05:40 AM
Leogane's Avatar
OK. I have a 1995 Nissan Maxima. I need to know the shim thickness for each valve so I know where each goes. The shims got shuffled during an engine rebuild and I need to put them back where they belong. Thanks for replying.
Old Oct 30, 2023 | 12:11 PM
Have you checked the Factory Service Manual (FSM)? See my signature for a free download where it says "click me".
EDIT: nevermind. You already started a thread on this topic and I answered you. Absolutely no reason to start another thread on the exact subject matter.
https://maxima.org/forums/4th-genera...-sequence.html
Old Oct 30, 2023 | 12:13 PM
JvG's Avatar
JvG
There is a specific valve clearance for intake and exhaust valves. One measures the clearance one has, then adjust to spec by adding ir removing shims.
You, nor anyone else knows what shim combination you had before parts got mixed up. So Noone can tell you which specific shim goes under which valve.
Few of us ever adjust our valves, even if owning the car since new.
Old Oct 30, 2023 | 12:57 PM
Leogane's Avatar
I have. I don't know if it was from you on a different post or someone else, it's not in there.
Old Oct 30, 2023 | 12:59 PM
Leogane's Avatar
I agree. I thought it was a different forum. The UI looked different.
Hayder Keledar
8th Generation Classifieds (2016-)
Dec 19, 2019 02:30 AM
motectransam
Jun 23, 2004 09:51 PM
irvine78
18
Dec 30, 2001 01:03 PM
radpp16
Aug 9, 2001 10:19 AM
maxima
Feb 20, 2001 11:37 PM
