Windshield washer fluid light bulb replacement
Not to big of an issue but anyone know if the windshield washer fluid bulb is replaceable on the back of the instrument cluster and easy to replace meaning not soldered to the board? I guess it has gone out because it doesnt illuminate on the dash lights when i first turn the key to ACC for the light check.
Here's the part number: 28911-1E400
I've done this mod to my 98 Max. Worked out great.
We are prewired for low washer level warning and the bulb is even in the instrument cluster. You simply need to buy the sensor, drill a hole in your tank, install the sensor and connect the wiring (connector is taped back near the washer pump).
dki378
18
Jun 10, 2005 07:03 PM
max95q
Oct 13, 2000 03:49 AM
