New ecm wont start
Old Feb 11, 2024 | 03:43 PM
ThomasC!'s Avatar
New ecm wont start
I have a 1996 Nissan Maxima with a new ecm that I put in and it has fuel it has spark everything is plugged in. But it still will not run on its own. I pulled the line on top of the fuel filter and gas was coming out. It only runs off of starting fluid. It will start off of it sit there for a second and then start to bogg down and I’ll spray a little more and it goes back to idle. But when I hit the gas, it doesn’t react. Anything helps just trying to get it running.
Old Feb 11, 2024 | 04:13 PM
FanaticMadMax's Avatar
It’s likely a fuel pump that happened to me when I was diagnosing it with starting fluid and it does dies after I stop spraying turn out pump was dead
Old Feb 11, 2024 | 04:24 PM
ThomasC!'s Avatar
I pulled the line from the fuel filter and turned the key and fuel came out of the line. Does it do that with a bad pump still. I can hear it prime too when I turn the key. But it’s acting like there’s no fuel.
Old Feb 11, 2024 | 06:22 PM
JvG's Avatar
JvG
Is your car manual transmission or automatic.
Please give us some history.
What was the original problem ?
What were the codes ?
Which repair attempts did you try, and why ?
What made you decide to replace the ecu.
Are you just firing the parts cannon to hope for success
2KxSEx
Oct 21, 2018 03:08 PM
-ReLLiK-
19
Mar 31, 2012 05:58 AM
ThreePointO
51
Jul 19, 2011 11:19 PM
MaXtUneD
Dec 30, 2005 02:16 AM
