Air conditioning issues
Old Aug 9, 2024 | 01:05 PM
Boatingnyc's Avatar
Hi - my 98 maxima seems to be having some ac issues. Though I got my mechanic to add Freon it's still not always blasting full cold air. Though I'm in Florida where the temp is close to 105 degrees. Does the engine need to run longer to blow colder air ? Any ideas on how to strengthen the ac ? Thanks in advance. Dan.
Old Aug 10, 2024 | 02:46 AM
Rit's Avatar
Rit
How long are you letting it run before you decide that the A/C is not working ?
Old Aug 10, 2024 | 04:56 AM
Boatingnyc's Avatar
not too long. But even after I'm on the highway for a small bit it doesn't go full blast to cool down . Maybe because temps are over 100 degrees and nothing I can do about it . But I notice newer cars don't have these issues
Old Aug 10, 2024 | 07:44 AM
Turbobink's Avatar
So you’re not worrying about air output/volume/velocity … you’re concerned about air temperature, correct?
Have you thermostated/thermo-metered the vent air temperature?
If not, do so.
If you have, what numbers are you getting?
Old Aug 10, 2024 | 02:43 PM
Boatingnyc's Avatar
If not, do so.
what vent do you get these numbers from ?
Old Aug 11, 2024 | 03:34 AM
Turbobink's Avatar
Center …
Old Aug 12, 2024 | 09:18 AM
slvr2KSE5's Avatar
center vent on speed 2. also check actual system pressures and post them here.
Kristinyoke99
May 12, 2023 03:59 PM
scutmud
Mar 27, 2016 05:43 AM
acw
Jan 5, 2015 04:18 PM
Stwodahorty
Apr 23, 2010 04:51 AM
MrBlank
Feb 10, 2002 07:00 AM
