1995 maxima crank, no start, then starts
Hello all, this is my first request! HELP!!
I am usually good at diagnosing, but I am in need of your assistance.
New battery, new starter, new crank sensor. Power to the coils. Plugs look normal.
Pulled the fuel line off the filter and it pumped gas for maybe 2 seconds and stopped. Cranked the motor and it punped a bit more. (I would think if there was no pressure, it would pump continuously.
Here is the issue...
She cranks, I will do a little and wait, do a little more and wait, not to over heat the starter. The engine will seem like it has a backfire, almost like it wants to start but burps. Then a little more crank and she starts. Overall about a 10 minute ordeal. Once started, purrs like a kitten. Drive it around and all is normal. Back to the driveway and hard starts. Then we are back to the crank and no start situation.
Normal it takes two rotations of the starter to fire up.
Any ideas?
Any ideas?
Any ideas?
Any ideas?
Most parts places will do loaner for a fuel gauge and fuel pressure specs/bleeddown specs should be somewhere here or online. You'll need the gauge as a starting point to diagnose accurately and not throw parts darts
Thanks for the suggestions, and the service manual download. Never had any trans work, just fluid change but will check the ground. Fuel supply had been on my short list to check and redo.
After 118K miles and 30 years, has to be something! Thanks again.
Checking the injectors on cylinders 2, 4 & 6 are easy. The others, not so much.
https://maxima.org/forums/4th-genera...nt-normal.html
maximus_96
Jul 27, 2004 09:55 AM
josh95se
Nov 17, 2000 12:42 PM
