Shifter slop - shifter return spring?
Old Oct 1, 2024 | 09:46 PM
aembleton's Avatar
Hey guys,
the shifter in my 97 is sloppy and loose when going into 1st and 2nd but it is tight when going to 5th. I assume its the shifter return spring or the bushing on the linkage, does anyone have links for either of these parts? I cannot find the spring anywhere. Can I still get these at the dealership, I want to confirm before I go.
All the parts were used when I swapped the into the car, I should have done this when I had it all apart but alas here I am.
I did tighten the two nuts that attach the shifter handle to the linkage and that did help but the side to side is still sloppy.
Thanks, I appreciate all the help over the years I have found here.
Old Oct 7, 2024 | 01:27 PM
95maxrider's Avatar
Lightly modded
I recommend finding the part numbers online first and doing web searches for them. Chances are they won't be available in any US dealerships, but there's a good chance you can have them shipped from Japan if you order from Amayama.
Old Oct 7, 2024 | 05:44 PM
RA030726's Avatar
I'm nutty for Nissans
Discontinued, in the USA that is.
34573-40U00 spring
https://www.amayama.com/en/part/nissan/3457340u00
34560-70N00 bushing
https://www.amayama.com/en/part/nissan/3456070n00
Old Oct 7, 2024 | 09:39 PM
aembleton's Avatar
34573-40U00 spring
34560-70N00 bushing
Thanks guys this is what I needed - I will be ordering shortly
Old Oct 9, 2024 | 08:59 AM
flames101sully's Avatar
A couple of years ago I ordered some original shifter bearings and the shifter spring from https://jp-carparts.com. That site along with the above mentioned https://www.amayama.com are where I have to go now to get a lot of OEM parts as the dealerships here in Canada don't carry most parts anymore. Either those or https://www.nissanpartsdeal.com/ .
dnice02
Nov 27, 2010 01:48 PM
one_fast_max
Mar 6, 2009 03:00 AM
jasonmax
Jul 28, 2008 03:59 PM
4dscPat
Mar 7, 2005 06:56 AM
Love_00_Max
Dec 8, 2004 12:18 PM
