Just fnished engine swap..lol made a big mistake
Old Mar 4, 2026 | 04:02 AM
Maximan007's Avatar
Hello everyone my name is Ray. This is my first post. I have been working on cars since i was 16 and love it as my hobby. I have a 1995 maxima 5 speed that my girl had when she was 16 and we have had it 17 years since high school. 5 years ago the engine overheated and locked up. I finally found an engine off Ebay after it pass compression tests I purchased it and finally installed. The car runs great but after wrapping up the install I noticed I had way to many vacuum lines and sensors that are unplugged. Come to find out the engine I got was Cali spec. the car was originally Fed spec. I have been looking at alllll types of pics online I cant really understand the visual from the manual. I could sure use some help if anyone has pictures. Even my vapor canister is unplugged both hoses. I have 3 sensors up front. One green that's plugged in and one brown and one blk that isn't plugged in. Any help would be appreciated. I have code 32. I'm going to clean the egr tube again but I think it's my vacuum lines are wrong. Thanks
Old Mar 5, 2026 | 01:17 AM
Rit's Avatar
Rit
With some searching on this website, you should easily be able to download the factory service manual for your car.
Old Mar 6, 2026 | 03:59 PM
slvr2KSE5's Avatar
swap all the fed spec stuff from the original engine to the donor.
Old Mar 7, 2026 | 07:23 PM
Maximan007's Avatar
Appreciate it guys. I also have the factory service manual but its a bit odd reading it. The throttle body i swapped so it fixed that extra sensor at the throttle body. I just need to know which metal lines to cap off and how to run the ones I have. Also seem the upper intake plenum has a metal nipple on the fed on a bit different then the cali spec one. I was able to make a hose that works for that. just need to see the rest.
bkbajan
Dec 22, 2011 02:34 PM
pavan87
Sep 30, 2010 10:08 AM
btbrown
Sep 14, 2008 07:16 PM
SpeedCrazie
May 29, 2005 03:27 PM
