Ecu and scan tools
Old Apr 9, 2026 | 06:24 PM
fattmaxx02's Avatar
Ecu and scan tools
I have a 95 5spd fed spec , my ecu code is A18-E10-ER0 which references correctly. Im having issues with a snap on triton scan tool. It will only communicate through the consult plug and not the obd2. Anyway that's not that big of a deal but what's really throwing a wrench in things is that its searching for a 4th 02 sensor. I was seeing if anyone else has had this anomaly.
Old Apr 10, 2026 | 08:03 AM
slvr2KSE5's Avatar
normal on early obd2 nissans. you need to use the consult plug or go in with global obd2 when using a real scan tool.
also, while im not 100% sure as its been years since ive been under a 4th gen.....but my 00 only has 1 downstream o2 behind the main cat as its a fed spec. im sure yours is the same.
danmack34
Feb 26, 2012 07:28 PM
t0mmyr
Jun 30, 2009 04:56 PM
icedout
Oct 8, 2007 04:07 PM
