Check engine blinking light codes
Old May 26, 2026 | 09:31 AM
Eke's Avatar
Eke
Hi!
I recently got a check engine light on my 1998 Maxima, and when checking the lights with the ecu screw i got the light to blink the codes 39 and 75.
I can’t seem to find anywhere to pinpoint what these codes mean, the car drives and behaves well, i recently changed the knock sensor and since then it runs like normal.
I have a obd2 scanner but i can’t get it to talk with the car, neither can my local mechanic, hence why i am trying this way.
Thanks for any input and help!
Old May 27, 2026 | 12:50 AM
Rit's Avatar
Rit
What year is your Maxima ? Have you tried downloading the Factory Service Manual to look for a definition of the codes, or even Google ?
Old May 27, 2026 | 07:25 AM
dsonnylal's Avatar
Does your clock work? If not, check the interior fuse panel for a 7.5 amp fuse labeled ELEC PARTS. There should be two fuses labeled this way, check both
Cashj2002
Nov 30, 2005 10:37 AM
shqipe
Oct 17, 2005 09:54 AM
DoGGx23
Jul 22, 2004 07:04 PM
tlove621
Feb 3, 2003 04:27 PM
