more hid problems
Old Feb 11, 2002 | 12:27 PM
maximabebe's Avatar
more hid problems
My passenger HID lamp is not as bright as the driver's side. Also, it flickers when i first fire them up and the driver's side is beautiful, but the passenger side is dimmer. HMMMM
Old Feb 11, 2002 | 12:53 PM
baby_boy21
Re: more hid problems
Which kit do you have? Is it the Hanabi kit? They are supposed to flicker when you first turn them on. Maybe there is something wrong with the harness. Give more details.
Old Feb 11, 2002 | 12:56 PM
SuDZ's Avatar
Just an idea. Try swapping bulbs from one side to the other. If it switches suspect the bulb if not then maybe it is the harness?
SuDZ
maximabebe's Avatar
Re: Re: more hid problems
It is a Hanabi kit.....only one side flickers then turns to a normal stock headlight color after a min or two.
Old Feb 11, 2002 | 01:34 PM
njmaxseltd's Avatar
I had the same problem. One bulb was beautiful and one was on the blue side. Contact Fredddie, 97gles, and he'll get a replacement kit for you. He's a good guy to do business with and will sort it out for you.
Old Feb 11, 2002 | 02:40 PM
Mishmosh's Avatar
Definitely switch the bulbs to see if the problem stays with the bulb. If it doesn't, the ballast could be the problem or even that headlight lense/reflector which may be cloudy.
On my Hanabi Kit, one bulb is slightly blue while the other side is almost pure white. I love them both and could live with either, but I want them to match! Definitely call Freddie up--he'll take care of you.
Old Feb 11, 2002 | 03:51 PM
SuDZ's Avatar
Good to know if things are not easily fixed that they backup the product.
SuDZ
Old Feb 12, 2002 | 05:22 AM
sp6040's Avatar
sorry to hear that.as far as flickering only when i first turn them on this happens then they are fine. i'm sure freddy will take care of you give him a call.
Old Feb 12, 2002 | 06:35 AM
1HOTMAX's Avatar
hint:
check all the connections to see if it's a connection problem, make sure u use ur old spring around an old 9004 bulb to make a tight fit.
1. swap the bulb around and see if ur other side does the same thing. if it does, then it's the bulb. call freddy, it's normal and have the bulbs swappped. upgrade to the purple ones! they are hot!
Old Feb 12, 2002 | 08:34 AM
baby_boy21
Re: hint:
I don't know if I like the purple that much. The blue looks sick. I accidently have a blue and purple. Im goint to Freddie to get a replacement bulb. The only thing I like about the purple is that is seems to be whiter, that is about it. But they both blink the he!! out of people!!!!!!hehehehe
Old Feb 12, 2002 | 09:10 AM
deezo's Avatar
Mine flicker when turned on but that's normal. As long as they burn at the same temp when they're hot, that's what matters.
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
Mochedda
Dec 15, 2015 11:27 AM
Vistance
Sep 17, 2015 05:17 AM
MidnightMaxima_22
Sep 12, 2015 06:02 AM
