Weird ECU Situation
Old Feb 11, 2002 | 05:51 PM
gholden1
Weird ECU Situation
My wife's 99 Maxima SE Limited (auto tranny) threw a code yesterday after an oil change (?).
I looked up the instructions for pulling codes, but when I popped off the plastic cover near the gas pedal, I found an ECU that looks similar but has stickers that talk about adjusting the idle!?!
There doesn't even appear to be a screw in there like the pictures with the instructions.
The ECU has had problems before and was replaced. Could they have put a 2000+ ECU into this car? I'm thinking they did something wrong.
Anyway... I still don't know how to get the codes.
Thanks for any help.
Greg
Old Feb 11, 2002 | 06:10 PM
MAXIPADMAN's Avatar
i think there is a code list on maximadriver.com
Old Feb 11, 2002 | 06:17 PM
Ravq's Avatar
http://vbxmaxima.8m.com/ecu.html
A search would have turned up this site. Please try to use it.
Old Feb 11, 2002 | 06:21 PM
clee130's Avatar
My friend's 99 Max is like that also... it seems that maybe some late model 99 Maximas might have gotten ECUs that were later placed in 5th gens.
Old Feb 11, 2002 | 06:46 PM
gholden1
Ravq: FYI, I did use the search facility and found (and read) the link you pointed to. If you'll re-read my post, you'll see that my ECU is not the same as the one on that site or it has a different sticker and is broken.
I just took a picture, but FTP isn't working for me right now.
The sticker does mention "Self Diagnosis", but it prominently displays
"IDLESPEED ADJUST" over the hole where the screw is supposed to be.
But the killer is that there is no screw behind the hole. I can stick a screwdriver inches into the ECU case through the hole.
Hence my inability to read codes. Ease up on the not so newbie.
Greg
Old Feb 11, 2002 | 06:52 PM
clee130's Avatar
Yep ... sounds exactly like what happened to my friend ... ECU is different.
Old Feb 11, 2002 | 06:54 PM
Ravq's Avatar
Greg
I merely stated a fact and I misread your post. I did not mean to be condescending in my response. Secondly, I'm more than willing to help anyone on this board regardless of rank status. As for you ECU I am of no assistance as I am unfamiliar with it but good luck anyway.
Old Feb 11, 2002 | 07:13 PM
gholden1
No problem.
I wonder if the dealer will have any info on what they did. It took them a few times to replace the first ECU. The first replacement simply relit the MIL light. The second replacement is the one currently installed. The first time they sent it home like that, the key wouldn't start it the next morning. It had to be towed in for some reprogramming.
Seems like an anti-ringer car (although not a lemon).
Old Feb 12, 2002 | 08:43 AM
gholden1
Found other people with the same ECU in this thread:
http://forums.maxima.org/showthread....eed+adjustment
Apparently the screw is a much smaller phillips head screw set further inside the ECU case instead of the flat-head screw flush to the case that I expected.
The poster did not report any idle problems after using the small phillips head screw in the same way as the flat head screw.
I will try it tonight.
Greg
Old Feb 12, 2002 | 02:30 PM
gholden1
Code 21. Ignition Circuit Fault.
I cleared it and it hasn't come back yet.
Thank you maxima.org!
Greg
Old Feb 12, 2002 | 02:56 PM
Ravq's Avatar
Way to go.
gigabyte
Jan 6, 2017 06:05 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
homewrecker
Sep 24, 2015 07:01 PM
