Alternator Help
Old Feb 13, 2002 | 06:06 PM
Ginuwin3112
Alternator Help
hey..not too long ago my max began to lose the charge in the battery, so i replaced the alternator and battery. it still cant keep the charge especially when u turn the headlights on...whats wrong??\
help is greatly appriciated!
Old Feb 13, 2002 | 09:09 PM
JAIMECBR900's Avatar
Re: Alternator Help
You may have a drain on the battery. Check the voltage on the battery with nothing on, if it is excessive then that may be your problem. Sounds like you do have one though.
Old Feb 13, 2002 | 09:35 PM
Eric L.'s Avatar
Sounds like you have a short somewhere which is draining your battery even when your car is off. Shorts are tough to find. You will need a volt meter which can measure resistance and lots of patience.
Old Feb 14, 2002 | 01:09 AM
Nealoc187's Avatar
SLOW
If you have an aftermarket stereo, CD changer, etc, check to make sure you have the 12V constant and 12V Power wires hooked up correctly.
Old Feb 14, 2002 | 06:59 AM
NmexMAX's Avatar
dot dot dot ...
How many amps is your alt. pushing?
Old Feb 14, 2002 | 04:10 PM
Ginuwin3112
autozone tested it and it stayed at around 26 amps..that doesnt sound too good...?
Old Feb 15, 2002 | 07:23 AM
NmexMAX's Avatar
dot dot dot ...
The 4th gens are rated at 100amps.
Old Feb 15, 2002 | 07:53 AM
SuDZ's Avatar
Wow. Then your only pushing about 25%. Maybe ou can get it rbuilt for a decent price in your area.
SuDZ
Old Feb 15, 2002 | 08:10 AM
NmexMAX's Avatar
dot dot dot ...
I got a rebuilt alt for 144 w/ a 84 dollar core. So total was 243, but then I took the core back and got back ~90 dollars.
Old Feb 15, 2002 | 09:17 AM
Ginuwin3112
...i put in a rebuilt alternator problem isnt going away
Old Feb 15, 2002 | 09:26 AM
95emeraldgxe's Avatar
if u got a hooked up stereo - i think u should get a capacitor that can hold atleast .5 farad
Old Feb 15, 2002 | 10:20 AM
mzmtg's Avatar
Minister of Silly Walks
You earned it this time...
Old Feb 15, 2002 | 01:20 PM
SuDZ's Avatar
Ok fine on that one I will agree he did.
SuDZ
Old Feb 15, 2002 | 06:04 PM
Steve Marsh's Avatar
Check your negative battery cable from the opposite end of the battery connection. You will need a 1/2 and or 3/8 drive rachet with an extension and a 12mm socket. Again just follow the cable down into the well of the engine compartment. You might have some play at this specific locality? Snug the nut to be sure that is not your problem. 96se auto (since new) all Amsoil lubricants/filters. replaced alternator at 115,000 miles, and starter at 157,000 miles although the starter still worked it was very tired! current mileage 164,300. Best Wishes! keep us posted!
Old Feb 15, 2002 | 06:39 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
...........and if none of that works, me n my mechanic had 2 pull each and every fuse to find a leak, and we eventually traced it 2 the oem security system ...... a bad unit was draining the battery overnight.
If that doesnt work, take it 2 dealer because electric prob's are a biatch
Old Feb 15, 2002 | 08:38 PM
exhip95's Avatar
Old Feb 15, 2002 | 10:32 PM
Chunger's Avatar
My other car is a Hybrid
Re: Alternator Help
As stated above... check the battery connections... clean with baking soda/water if you got that 'crusty' stuff on them...
You can also have the battery 'load tested'.
TallTom
57
Oct 14, 2025 05:16 PM
homewrecker
Sep 24, 2015 07:01 PM
