MAX tire for 17 Mustang wheel
Old Feb 15, 2002 | 06:31 PM
DPAmax5SPD's Avatar
Hey yall
I hope nobody bites my head off.... about using the search engine instead, but ive already used it for about an hour and cant find info on this idea... I need to know what the maximum tire size on a 95se i can install on a 17X8 wheel( Mustang Wheels) i am looking at probably a 245-50 or 55- 17..........does anyone know if this will fit and also does anyone recommend a tire size.... I am buying used tires so pickings are small........ Thank you for your help//Richard
Old Feb 15, 2002 | 06:33 PM
97BlackMax's Avatar
Re: MAX tire for 17 Mustang wheel
Originally posted by DPAmax5SPD
Hey yall
here's a tire calc where you put in the stock size and the new size and it will tell you information about the differences...
http://www.miata.net/garage/tirecalc.html
i think the stock size is 205/65/15..at least that's what it is on my 97 GLE, i'm pretty sure...someone correct me if it's different
Old Feb 15, 2002 | 06:34 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
USE THE SEA... oh. try 255/50/17 but goin to 55 series would throw things off spec...... 50 series keeps speedo in check...
hmmm...... I wanna see pics of a max with rustang wheels....
Sexima G T R
Old Feb 15, 2002 | 08:30 PM
Xtreme5053's Avatar
Re: Re: MAX tire for 17 Mustang wheel
Sexima G T R
no, no, you're on crack, the proper size tire is 235/45/17 for a 17x8 wheel on a maxima
Old Feb 15, 2002 | 08:53 PM
JMKeehn's Avatar
Re: Re: Re: MAX tire for 17 Mustang wheel
Being an 8-inch rims, you may be able to go wider with the tire, therefore changing the profile to a lower number. For example...a 235/45/17 tire has an overall diameter of 25.3 inches...a 265/40/17 has the same exact diameter at 25.3 inches. If the 265/40/17 will fit on the rim, you could use that size tire as well. You've just got to play with the numbers. Pay attention to tire diameter, because that's what's going to make sure your speedometer accurately reads your rate of speed. I've got 235/45/17 on my car, but I have a 7 inch wide rims, not 8". Are you going with the Cobra rims? I thought about getting those for my car and changing the center cap...
-Josh
Old Feb 15, 2002 | 09:28 PM
DPAmax5SPD's Avatar
Re: Re: Re: Re: MAX tire for 17 Mustang wheel
-Josh
I am going iwth the 96-97 cobra 17x8 wheels
they have no emblems or anyting they are the diamond cut alloy 5 stars
yeah baby hehe..... you think i could fit a 245-50-17?
Old Feb 16, 2002 | 12:31 PM
Nealoc187's Avatar
SLOW
Re: Re: Re: Re: Re: MAX tire for 17 Mustang wheel
245-50-17 will work fine... but do you understand that this tire is really tall, your sidewall will look abnormally large, and your speedo will be off significantly...
If you want to get a 245 wide dire get 45 or 40 series. I'd go 40 series. 50 series will look stupid.
Old Feb 16, 2002 | 12:36 PM
JMKeehn's Avatar
Yeh, you probably could, but your speedometer is going to be off by about 3 miles an hour. When you're speedometer reads 60, you're actually going to be going 63. Your tires are going to be about a quarter inch wider, but they are going to be about half an inch higher, too. They may rub, but I'm not going to be the one to say that they will or won't...
-Josh
Old Feb 16, 2002 | 01:54 PM
DPAmax5SPD's Avatar
Re: Re: Re: Re: Re: Re: MAX tire for 17 Mustang wheel
-Josh
yeah speedos dont mean anything to me anyways
comon gentz who does the speedlimit here anyways.....
I had 3 mustangs and 2 z28s fully moded in the 12s and 11s.using different rear end ratios, which threw off the speedo gear so its no big deal, just wondering if they would fit thanks
Old Feb 16, 2002 | 08:21 PM
JMKeehn's Avatar
Re: Re: Re: Re: Re: Re: Re: MAX tire for 17 Mustang wheel
That's cool. There's a guy who just put on 245/35/21 on his car. It's lowered as well, and he had to roll the fenders, from what I understand. Looking at that, I'm thinking you may be all right. How low is the drop with your springs?
-Josh
Old Feb 16, 2002 | 11:05 PM
DPAmax5SPD's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: MAX tire for 17 Mustang wheel
-Josh
2 inch with dropzones
Old Feb 18, 2002 | 02:19 PM
JMKeehn's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: MAX tire for 17 Mustang wheel
Driving, you should be okay, but when you go to make a sharp turn, I'm willing to bet that you're going to have some scrubbing.
-Josh
dank4us
34
Jun 10, 2024 03:45 AM
Roymg
Sep 3, 2018 05:10 AM
02nissmax
Sep 5, 2015 01:50 PM
homeyclaus
Sep 3, 2015 06:15 PM
twotonezed
Aug 16, 2015 11:41 AM
