fuel pump
Old Feb 17, 2002 | 04:15 PM
garbear's Avatar
fuel pump
Just a quick question. Where would be a good place that I could get an upgraded fuel pump? and about how much do they run?
Old Feb 17, 2002 | 05:05 PM
Chunger's Avatar
My other car is a Hybrid
You can probably get a Walbro pump for the DSMs... Some people are having some problems tuning them it seems...
Do you really need one? are you using 100+hp shot of NOS or something?
Old Feb 17, 2002 | 05:33 PM
garbear's Avatar
I wish
No.... I'm just wondering about how much that would cost and if it would be a worth while mod for potentially getting a supercharger/NOS. Or would I be better off with just upgrading the injectors?
Old Feb 17, 2002 | 05:41 PM
nigelcmf's Avatar
I have a Walbro 255 lph. It is definitely worth getting if you are running higher boost 100 shot nos or S/C
I am having some problems with mine running stock cos the pressure is much higher than stock. I would do it closer to when you decide to run boost or do it together. The only problem I have seen with running with stock is that idle is 900 rpm instead of 650. I have tried adjusting it but it comes back to 900 again after a day or two of driving.
Old Feb 17, 2002 | 05:45 PM
garbear's Avatar
another dumb question
Ok....well let me ask this then... Is there any way I can adjust the fuel pressure on the stock fuel pump? Honestly I haven't looked but I thought I'd be a fool for five minutes rather than be a fool for a lifetime for not asking.
Old Feb 17, 2002 | 06:36 PM
1MAX2NV's Avatar
Re: another dumb question
Adjust fuel pressure via aftermarket fuel pressure regulator.
Old Feb 17, 2002 | 06:38 PM
garbear's Avatar
Re: Re: another dumb question
Sweet.....thanks.
Old Feb 18, 2002 | 09:09 AM
nigelcmf's Avatar
I think that this will allow you to limit maximum fuel pressure. I don't think it allows you to boost pressure. If it does allow you to boost pressure, your flow goes down ... just like when you squeeze a hose pipe, pressure goes up, throughput goes down.
The more important question here is the sustained throughput for a given pressure. That's what upgrading your fuel pump is all about so as not to run lean.
I don't think there is any alternative other than buying a pump (either internal or external).
Old Feb 18, 2002 | 12:02 PM
garbear's Avatar
Re: Re: Re: another dumb question
That's kinda what I was thinking.... but before I do that I need to get some measurements as far as if I am running lean or not.. (probably should have done that before I asked this) but I just wanted to see what could be done if I am. Is there a special guage I can use to check on that?
Old Feb 18, 2002 | 01:48 PM
nigelcmf's Avatar
Re: Re: Re: Re: another dumb question
There are a couple of things you can use:
1. A/F ratio meter. These are usually not very accurate. They run from your O2 sensors. Unless you buy an expensive one with its own sensor, I wouldn't bother.
2. EGT, is probably the preferred choice. Depending on where you put the probe, you can tell if you are running lean from the temp reading.
Old Feb 18, 2002 | 02:17 PM
1MAX2NV's Avatar
Nope..not for his purpose. He's NA. If he's planning on raising fuel pressure up to 100 psi on a stock pump. Yes, the LPH will go down on a stock pump. If he's doing anywhere less than 75psi, the stock pump will still flow enough.
Old Feb 18, 2002 | 02:35 PM
nigelcmf's Avatar
Dude, you're right, but read his second post. it talks about S/C and NOS etc. Like I said in my first (or second) post, I would wait till he's ready to actually put on the S/C on NOS. If he wants to increase fuel pressure with stock pump and no boost, that's OK....but WHY? I had thought he meant increasing fuel pressure for NOS/ S/C with stock pump.
jmlee44
Oct 2, 2022 02:13 PM
Miket2006
Mar 1, 2021 03:55 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
