60' times 16"v18" wheels
![](https://maxima.org/forums/images/smilies/support.gif)
I've been reading lots of track posts lately and I plan on going to the track right after I install my new suspension (hopefully it'll get rid of my wheel hop). Everyone talks about different launch techniques, shifting, and of course 60's. The thing that bothers me the most are my best slips. My 18"s weigh ~20-21lbs and they have 235/40/18s on them.
Best 60' on 18" 1/8=9.898 (I must have missed a shift
Best 1/8mi on 18"s 1/8=9.774
Best 1/4mi on 16"s 1/8=10.030
I think my clutch may have been slipping before the 1/4mi run which definitely wouldn't have helped things, but I was really surprised with my 2.181 60' on my 18"s. On my next run at the track I will have modified my JWT to be a hybrid, put in my ACT clutch, and put in shocks/springs so my 60' should get better. I just don't know which wheels to run
-hype
![bawling](https://maxima.org/forums/images/smilies/bawling.gif)
![got me](https://maxima.org/forums/images/smilies/ne_nau.gif)
-hype
how is that possible
are those rims lighter than stock, it was my understanding that wheels usually slow you down unless they provide less rotational mass. if this is the case with your wheels then i shouldnt sound stupid. heh heh. yah i dont get it because your 60's were worse with the 18s, please explain to me.
Re: how is that possible
-hype
From those 3 timeslips you can't make an accurate decision. Just because you happened to pull a good 60 on your 18s once doesn't mean you will all the time, obviously, as the other two 60' times totally suck (no offense, its obvious you are capable of better though). Do you have more timeslips we can analyze your runs with? If you can, take a look at your 1/8th mile trap speeds. I'm willing to bet that your 1/8 mile and 1/4 mile trap SPEEDS will be better with your 16s.
Of 11 runs on my 16s my best 1/8mi times were low 10s. I average more of a 10.2 though.
Of ~25 runs on my 18's my best were 9.7s, but I also got 9.8 and up to 10.2. My average time was probably closer to high 9s or low 10s.
So overall my times are still better on my 18s. Maybe I'll make a spreadsheet later to figure out my average 1/8mi time and average 60's.
-hype
-hype
-hype
-hype
Originally posted by Nealoc187
I am interested in your speeds not times. Whichever wheels show you better SPEEDS are the ones you need to use. If its your 16s that show faster speeds but you have less traction and therefor slower times, you need to work on launching your 16s. If its on your 18s then thats just plain weird in my book, but go with what works.
Spreadsheet
The speeds are all about the same, but my highest speed was on my 18"s
-hype
I just did a little fiddling with your spread sheet. Without the two 72mph speeds on your 18" wheels, which honestly look like flukes given the rest of the data, your average mph was 70.633. On your 16s, minus the freak 57 and 62mph speeds, your average is 70.80. Not much difference.
One question, have you been running on your 18s LATELY and were you running on your 16s BEFORE? If so, I think I'd chalk your improved 60 times up to experience rather than the wheels.
Either way, you need to give it some more clutch or less gas off the line, because honestly, those 60' times are absolutely horrible. I assume you're spinning badly, rather than bogging. Whats your launching technique, maybe we can nail down some other technique to help you get those 60' times down.
![laugh](https://maxima.org/forums/images/smilies/laugh.gif)
-hype
If I wanted to borrow bricks I'd call up Stan so I could borrow his 35lb. momo arrows (that's without tires too)![Wink](https://maxima.org/forums/images/smilies/wink.gif)
-hype
-hype
Re: 60' times 16"v18" wheels
-hype
-hype
alixc
08-11-2020 01:48 PM
trasmadean
02-01-2017 08:20 PM
vingodine
45
05-21-2016 12:46 PM
